Reply 40 of 82, by megatron-uk
To use an IDE drive (be that a CF card or a spinning 3.5" HDD), you are going to need an IDE BIOS; and it appears that your system doesn't have support since you say it only works with MFM drives - your options are:
- An XT-IDE card, with CF slot and on-board BIOS.... this is an all-in one, plug and go solution. The XTIDE BIOS adds IDE support to your mainboard BIOS and will scan and use any CF card you have plugged into the XT-IDE card. You can get various models of this - multiple CF slots, 3.5" IDE headers, no CF/3.5" headers etc.
- An XT-IDE BIOS, burned to an eprom, plugged into a network card - this gives you the IDE BIOS addon to your mainboard. But you then still need an IDE controller card to give you the 3.5" IDE connectors, floppy, serial etc; though these are quite common.
- A third party, period IDE controller with on-board BIOS. Like a Promise or similar. Though these are pretty difficult (and expensive) to track down.
Since you already have working floppy, serial etc. I'd suggest the first option is the easiest.
https://www.target-earth.net
