First post, by Badscrew
Hello, Vogons!
I've just got a 486 PC and the first thing I was looking to is its BIOS battery of course.
In mine I see this is a rechargeable (?) Ni-Cd thing, should this be considered a time bomb too, like the Vartas and other non-rechargeable ones?
Reply 2 of 34, by zapbuzz
replaced mine yearly back in the day and whenever I got a motherboard with one on it.
they generally last 3 to 5 years but like all rechargeables they're optimal within 2 years.
Reply 3 of 34, by bloodem
As others have pointed out, get that sucker out FAST!
Though the photo quality is pretty bad, I see what looks like corrosion next to those resistors above. So you'll need to handle that as well (tissue soaked in vinegar & IPA should take care of that). Depending on the damage, you might need to redo the soldering on the affected pads.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 4 of 34, by Deksor
Well this *is* a varta battery I think. Most people call this form factor of NiCD batteries "varta batteries" because most (all ?) of the are made by varta.
Like the others said, get it out asap, and if it started to leak, clean your motherboard with some white vinegar.
Reply 5 of 34, by Vynix
Yup, that's the classic Varta NiCad barrel of corrosive Death, the embodiment of Evil itself.
Get that thing out before it eats up the traces on the mobo.
Reply 7 of 34, by CalamityLime
Looking at those resisters, my guess is that it has already leaked a little bit.
Try adding a drop of vinegar to the area where the battery was and seeing if it reacts to anything. If it does, get to cleaning before the battery juice starts eating away at the board. It's not a fun process the stuff spreads far and wide some how.
If it's sold in your area, get the concentrated vinegar, it would cut down the wait time.
BTW, most people call battery juice, battery acid and get confused when it reacts with vinegar. Those type of batteries are basic and thus react with the acid in the vinegar.
Be Happy, it's only going to get worse.
- Projects
Limes Strange 3D models
USB-2-232
Reply 8 of 34, by Badscrew
Well
Could've been worse I guess.
The SIMM sockets and the board around affected resistors cleaned up ok (I hope there is no damage under the sockets, that will be impossible to repare)
Two SIMMs were eaten, I won't be surprised if those won't work.
After the cleaning
Reply 10 of 34, by Badscrew
The green halo between the battery terminals is the electrolyte going between the layers, can't do anything to that. Hopefully this didn't short out or ate the traces there.
I'll see how this thing boots up!
Will probably first try to boot it with 6 Ram modules instead of 8, don't want the two corroded SIMMs to add another unknown variable to the troubleshooting...
Reply 11 of 34, by H3nrik V!
Badscrew wrote on 2021-07-26, 22:08:
Good decision! The less unknown, the better!
Reply 14 of 34, by bloodem
CalamityLime wrote on 2021-07-26, 19:40:
Come to think of it, it's actually quite unbelievable how it sometimes spreads. I mean, it literally appears in distant places, far away from the battery, without showing a clear path to how it got there. Magic, I guess... 😁
Doornkaat wrote on 2021-07-27, 10:24:
All 486 I know of will only work with four 30pin SIMMs in each bank. Six modules will cause problems.
That's valid for all 386 / 486 boards with 30 pin SIMMs. Each 30 pin module provides 8 bits of data, so you need 4 modules for the full 32 bits.
Badscrew wrote on 2021-07-26, 22:04:
The first 3 slots should really be removed (with a desoldering gun and some experience it's not very hard). My guess is that there's a lot of gunk underneath, and it will continue to eat away at all those traces that go under the memory slots.
Reply 15 of 34, by Badscrew
Good to know!
I'll create a separate topic for this PC revival.
Reply 17 of 34, by Badscrew
bloodem wrote on 2021-07-27, 11:16:
This is what i fear.
Don't have the desoldering gun - but this may be the reason to get one finally 😁
Reply 18 of 34, by darry
Badscrew wrote on 2021-07-27, 13:07:
That is on my list as well . Maybe somebody can give some recommendations as to what to get .
Good luck with the board .
Reply 19 of 34, by bloodem
darry wrote on 2021-07-27, 15:01:
I've been using this one for a few years and it's been great.
There is a learning curve, though. And, of course: The. Tip. Must. Always. Be. Clean 😁
