First post, by butjer1010
Hi, please, does anybody knows which type hdd (1-66) i have to input in system diagnostic? I have conner cp30101g 120MB inside, but i cannot match hdd type. I tried 50, as stated in manuals for this disk, but it says primary hdd error. This disk worked normally, but after "loosing" power in Dallas cmos battery, i cannot install DOS again. Now i have fixed the cmos battery, and i cannot go further than system diagnostic settings(SP0308).
Thanks in advance
Reply 1 of 7, by leonardo
butjer1010 wrote on 2021-08-06, 20:19:
Thanks in advance
According to this reference these settings should work:
MODEL: CP30101G
CYL: 762
HDS: 8
SECT: 39
WPCOMP: 0
LZONE: 762
Type: IDE
You say the type field asks for a number, though? Does any of the presets for type allow you to set the other parameters by hand?
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 2 of 7, by butjer1010
leonardo wrote on 2021-08-06, 22:07:
According to this reference these settings should work: […]
Thanks in advance
MODEL: CP30101G
CYL: 762
HDS: 8
SECT: 39
WPCOMP: 0
LZONE: 762
Type: IDE
No, there are no presets for typing manually all of this data. I found that also, but, i cannot use this data in setup diagnostic! Only the selected presets.
Reply 4 of 7, by Jo22
Hi, can you boot from floppy?
If you can, please try IDE-Diag or WhatIDE. They can find out physical drive geometry.
Re: IDE disk-on-module + 386
Good luck! 🙂
Reply 5 of 7, by butjer1010
Romain wrote on 2022-02-23, 13:52:
Hello, I've found a various value for CYL, on a Compaq User's manual for this model. […]
CYL: 760
HDS: 8
SECT: 39
WPCOMP: 0
But, do you have an error code eon the screen at boot ?
I already changed the disk in this machine, and manage to install dos 6.22. Thanks anyway.
Reply 6 of 7, by butjer1010
Jo22 wrote on 2022-02-23, 17:08:
Hi, can you boot from floppy? If you can, please try IDE-Diag or WhatIDE. They can find out physical drive geometry. Re: IDE dis […]
Good luck! 🙂
Thanks mate, i've changed the disk, and everything worked ok.
