Reply 20 of 30, by schlomoe99
cyclone3d wrote on 2021-08-26, 02:16:
Another option is to use fishing line and springs to secure the heatsink. The springs of course will be on top of the heatsink or in channels in the heatsink. You would have the fishing line going around the card top to bottom. I've done this before and it works well.
This. Fishing line is extremely underrated as a way to secure heatsinks. I've successfully used them on the CPUs of several socket 3 systems. What's nice about it is that it is cheap, it holds the heatsink securely in place, non-permanently, and it is so thin that its effect on efficiency for heat dissipation is negligible. Give it a try, and I'm sure you would agree. Good luck!
Reply 23 of 30, by Doornkaat
Kahenraz wrote on 2021-08-26, 11:06:
I'm not familiar with fishing line. Isn't it usually made out of a kind of plastic that would be at risk of melting?
It's usually a single nylon thread so it should survive higher temps than the chip.😉
Reply 24 of 30, by Chadti99
Following, I get a fantastic overclock with the cooler shown but the adhesive thermal tape I’ve tried only holds for about a week. I need to try with fishing line or superglue next. Would love a custom mount though.
Reply 26 of 30, by schlomoe99
Doornkaat wrote on 2021-08-26, 11:13:
I agree. Monofilament fishing line, which is readily available and inexpensive, has a crystalline melting temperature of around 230 °C, and a glass transition temperature in the range of 70 °C.
https://www.sciencedirect.com/topics/engineer … ng/monofilament
You'll be fine!
Reply 27 of 30, by Chadti99
Kahenraz wrote on 2021-08-26, 12:25:
I have that exact cooler. It's excellent as a CPU cooler but it's very heavy and is not a good match for thermal tape. Try an aluminum heatsink instead.
How are you overclocking your PCX2?
I swapped in a new crystal, 18.45 to get an 85Mhz clock if I remember correctly.
30fps in Quake 2 at 640x480x32
MW2 also super smooth
Reply 29 of 30, by Doornkaat
The clockspeed of the PCX2 isn't derived from the PCI clock but if you overclock your PCI bus too much the cars won't work properly.
Not all motherboards have PCI and FSB linked though. Some offer dividers, others have a fixed PCI clock.
Reply 30 of 30, by drosse1meyer
Doornkaat wrote on 2021-08-26, 09:25:
A fan blowing across the chip will do you more good than a small passive heatsink.
This. I was able to make a 'bracket' out of some plastic runway i had laying around, attached a fan to that, screwed it down to a slot, and mounted right next to the card. Works like a charm, and I don't dirty up the nice card or risk damage trying to remove crap later on.
