First post, by Vipersan
A short time ago I aquired a GA-486VF rev 7 in a very sorry non working state ..
It was bare bones and had suffered some really bad battery corrosion ..along an inch strip at the edge of the pcb.
I knew it would be a challenge ..but had to at least try.
Some of the traces were simply not there in places ..dissolved.
But I added wire links topside following the traces original paths.
I also replaced 2 electrolytic capacitors which were bloated and the plastic sleeves shrunk.
330uf at 16v
I also had to remove the psu connector to work and clean underneath it.
Next ..a new 5 pin keyboard connector din ...some pins had dissolved inside the original.
OK the last hurdle physically was to replace the varta battery (already removed) with vertically mounted 2032 coin cell and series diode.
All this can be seen in the photos.
The only cpu I have which hopefully is suitable is an AMD 486-DX-100
..but there are so many jumpers it is more than a bit confusing ..and they were all missing.
So far I have fitted 3 which again can be seen in the photos as they are Red.
So at this point I just want to establish if it works.
I have powered up with no CPU ...no ram and chips missing which presumably are Cache.
...and a post/diagnostic card in the 8 bit ISA slot..
All supplies appear to be present and correct ...and the cpu clock led does light up.
..but I dont want to power up with the cpu fitted until someone else take a look..hopefully one of you guys is familliar with this ISA/VLB mobo ?
please check the photos.
There may well be other issues with this board ...but I gotta start somewhere.
rgds
VS
There were other issues with this motherboard.....which refused to boot a few hours after nailing the problem regarding not able to comlete boot and drive a video card..
That fault was eventually traced to a faulty from new POST diagnostic card which was grounding bit 3 of the ISA bus.
The POST card was eventually repaired ...details are on pages 7 snd 8 of this thread ...
After Several hours of running the motherboard refused to even start up ..
This fault was eventually tracked down to L1
A brief summary of this -
Basically the fault (in short) was traced to an open circuit or very high resistance ferrite chip surface mount inductor.
Other ascociated components have already or will be changed in the near future.
This inductor is responsible for the 5v supplies to the clock processing/generation IC for the CPU ...so no clock ..no startup ...and the cpu remains in reset.
So the mobo was eventually fixed...but still misidentifies the DX4-100 CPU at boot
This is yet to be solved.
For anyone interest the Bios dump from this board is on this page...a bit lower down.
The thread jumps about a bit so on advice I've edited this first post...and next time I will start a new thread before switching topics mid stream.
rgds
VS
