Be aware that the filament is only turned off while standby on relatively modern CRTs, near the very end of the CRT era (e.g. mid 1990s+).
For almost all older ones, thus it is advisable not to have it turned on when not used.
(Edit: Power cycling too often is also a problem with many older CRTs. Observe the filament while turning it on cold. Older ones usually get very bright for a moment until the temperature causes the filaments' resistance to increase and reduce the current. This is very stressing and the majority of filament breaks occur at turn-on. More modern monitors increase the filament voltage/current slowly to avoid this stress moment, you see this by it getting brighter gradually and not "flashing up" instantly)
Horizontally collapsed image usually is caused by a problem in the vertical stage, most likely defective vertical driver, coil and connectors. Not a big issue for experienced TV repairpeople.
Extra cooling and not operating with excessive brightness is always advisable, in particular with the very last Sony's in 16:9 format, whose horizontal transformer is particularly sensitive (because undersized) and no replacement spares available.
Overly high contrast itself does not increase radiation, as the thing that causes radiation is the HV current.
But excessive focus voltage tends to wear out the tube itself prematurely, particularly a problem on Trinitrons.
