First post, by Hiddenevil
Was just wonder if anyone else has one of the old AT Compatible computers.
There's an old android saying which I believe is peculiarly appropriate here. In binary language it goes something like this: 001100111011000111100, which roughly translated means: "Don't stand around jabbering when you're in mortal danger!"
Reply 2 of 10, by Hiddenevil
Hi Alex!
Do you have the original Diagnostic setup disk?
I think I found a copy with a file called PCDIAG2, but it doesn’t seem to run.
I’ve had my 7200 for nearly 10 years and never been able to properly configure the BIOS
Reply 4 of 10, by Hiddenevil
Thanks buddy, can I ask how you manage to configure the bios on your machine?
Reply 5 of 10, by Hiddenevil
ajacocks wrote on 2021-10-15, 01:10:
Let me check, but I don't believe that I do. I'll image it if so.
- Alex
Any news Alex?
Reply 7 of 10, by Hiddenevil
Idk if the 4600 uses the same setup software
Reply 8 of 10, by nuno14272
That's a good question... Been a while since i fire it up. Dont remember if i used a specific boot disk or just dos 3.0 boot disk.
got to check it out
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 9 of 10, by Hiddenevil
Thanks, still waiting on Alex
Reply 10 of 10, by ajacocks
Yeah, and I don’t seem to have the setup disk, sadly. At least not that I have found, so far.
I might have found a good solution!
Check the post here:
https://www.vcfed.org/forum/forum/technical-s … 82976#post82976
That jogged my memory, and I remembered that every 286 clone is an exact clone of the IBM AT. So, the same setup/diag disk will work on all of them. You can also use gsetup:
https://ibm.retropc.se/5162/setup/5162_gsetup.html
- Alex
