Reply 20 of 24, by maxtherabbit
- l33t
Tiido wrote on 2021-10-17, 23:56:It made the most sense to me, one has pins going 12345 6789 on DB9 end, and other 13579 2468, one is sequential, other is staggered... Easy to tell when you lift back the shroud on the DB9 side and that's where the naming came from.
Yes, but the ambiguity comes from the fact that the opposite is true if you consider the pin numbering of the Dupont header
