First post, by Mamba
Hello,
any chance there is another working page that contains the excellent p2b series update guide?
http://homepage.hispeed.ch/rscheidegger/p2b_p … pgrade_faq.html
Reply 2 of 4, by BitWrangler
Older one in case that's better saved https://web.archive.org/web/20091017031927/ht … pgrade_faq.html
Reply 4 of 4, by PARKE
Mamba wrote on 2021-10-19, 14:05:
Great thanks!
So no hidden 133 setting for my p2b-s 1.03 it appears.
There is one but it usually does not work properly.
73.16 KiB
(edit) the malfunction is mentioned in this forum thread:
("Yeah, upgrading older P2B-series boards would be a lot simpler if the
9150-08 133Mhz setting actually worked, instead of producing an ugly
signal the BX interprets as 109Mhz.")
https://www.motherboardpoint.com/threads/need … mod-help.22785/
Also, the guide by Roland Scheidegger mentions an essay on RAM for 440BX - see attached.
RAM modules compatible with motherboards based on the i440bx chipset.doc
73.5 KiB
34 downloads
