Reply 80 of 138, by Nexxen
- Oldbie
Error 0x7CF wrote on 2021-11-23, 17:39:Not quite. On old systems like 086/088, 186, 286, 386, (and 486 before clock multipliers), the bus clock speed and CPU speed are […]
Nexxen wrote on 2021-11-23, 10:51:I was thinking, isn't the increase in mhz going to yield a linear increase in performance?
Not quite. On old systems like 086/088, 186, 286, 386, (and 486 before clock multipliers), the bus clock speed and CPU speed are the same. So, for them increasing the CPU speed does yield a pretty much linear increase in performance, as long as you ignore any performance limited by ISA, which can only really clock up to 8-10MHz safely unless you're picking your ISA cards carefully. In simpler systems (some 8088, some 8086, some 286) where the CPU, Bus, and ISA are all run at the same frequency, a frequency increase is a completely linear performance improvement since it increases the frequency of everything in the system.
You won't reliably be able to exceed whatever Bus speed your board has for its maximum setting. So, after a certain point, you want to increase CPU performance without increasing bus speed.
One way to do this is to make your instructions take fewer cycles to complete. This technique is referred to as "Increasing IPC", increasing Instructions Per Cycle. Many x86 instructions take several clock-cycles to complete. In real CPUs, this was done with the NEC V20/V30, and is why those are known to be faster than their 8088/8086 counterparts at the same clock speed. IPC is improved with pretty much every new CPU generation (except the Pentium 4), and is why a 8MHz 286 system can outperform a 10MHz 8086 system.
Another option is to introduce/increase cache, and reduce dependence on the slow main memory. Even when the Bus and CPU ran at the same speed, DRAM is slow, so going out to memory to fetch a value is going to slow execution down. If you have a cache onboard or on-chip (and the value you want is inside the cache) you can read from the much faster SRAM cache memory and not have the CPU waiting for your slow main memory to respond.
Another option is to increase CPU clock speed without increasing the Bus speed. In real CPUs this happened in the 486 era when Intel started clock-doubling. This especially works well if you have a cache on-chip which can run at your doubled/tripled/etc clock speed, and prevent slow accesses to your now half/one-third/etc-speed Bus. Full-speed on-chip cache in combination with clock-multiplication is what makes the 65F02 fast. It has enough RAM inside it to almost never have to touch main memory, and all the ram inside it runs at 100MHz, vs the previously incredibly slow 1MHz system ram.
Nexxen wrote on 2021-11-23, 10:51:186,286,386? Some FPGA could come with L1 + L2 cache, are the new performance results predictable?
The new results could be simulated and compared to a simulated version of the old results, but I'm not remotely smart enough to be able to do that. A cycle-accurate emulator would need to be implemented to be able to check, which is pretty much the same amount of work as implementing the device on an FPGA to begin with.
Nexxen wrote on 2021-11-23, 10:51:Isn't a BIOS necessary for these new cpus? I can't get around the idea of some support updates.
Or being internally clocked x2/3/4... doesn't need?Probably wouldn't need a BIOS update as long as it behaves mostly like the original chip. NEC V20/V30 don't need BIOS updates. 486DX2 in a system with a bios that only knows about 486DX doesn't need a bios update to clock-double.
Thanks a lot!
At some point you need to go with a whole new design. It's not only the increase of speed but a combination of factors.
IPC was the death of P4, I remember good old Tom's articles about it.
W.x. wrote on 2021-11-23, 20:52:cyclone3d wrote on 2021-11-23, 00:40:But that would have all been done by hand for the most part... now with way more advanced tools and faster computers, things more complex can be made much easier.
There are design tools, etc that can help out a ton. Plus if making something x86, because the instructions are already known it is feasible that somebody could design one from the ground up.
Again, you can design more complex CPU, or even new platform, but you won't make chip in home conditions, that is more advanced, than original one. Your chips would be larger, and thus, generate more heat, etc... How do you want to make more complex chip than 4004 in home condition... with limited budget. Without building a factory, or buying incredible expensive machines.... I've explained it once, it would be profitable only if you would sell thousands of them. For larger factory and machines, you need tons of water and energy. Not only buy machines. You need also personal, that know work with it, you need to buy waffers, pay for water, energy. It would go to millions. Just for making 10 or 20 or maybe 100 chips for 8086, 286 or 386? I just cannot imagine it in reality. Unless you buy machine, that can cost up to 10000$ or 20000$ (for you own money ... but I would guess no such cheap machine exists), and that all with energy, water and cost of waffers, you cannot make new chips, your initial investition needs to be millions to build factory that can produce at least one chip... but then, when you start that power and resource hungry factory, you just need to go and go with new chips, otherwise, it wont pay investition. So to make new 286 or 386 chip, it would possible only if equipment costs several thousands dollars. In reality, noone will pay so much money for enhanced 286 or something, you will need to mass produce it.
Economy stand point, it just costs too much.
Way too much to be a viable solution.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
