First post, by badmojo
I'm a total noob when it comes to EPROMs but I have 2 PCI VGA cards here which are fundamentally the same hardware, but which have different BIOSes, one of which performs better than the other. I've tested this by swapping the BIOS chips so I know it works - what I want to do is copy the good BIOS, burn it to a new EPROM, and put the copy into second card.
The card in question is below - I've done a bit of reading here and and people are recommending the TL866CS programmer which I can find easily online.
What I want to confirm before I dive in though is:
- is this programmer suitable for the sort of chip I need? It obviously needs to be able to read the old one and write a new one. Alternatively I could just skip the read and try and ones uploaded here: http://www.vgamuseum.info/index.php/cpu/item/ … logic-ark2000pv
- what sort of chip do I need??
Thanks for any help.
Reply 1 of 12, by jakethompson1
Here in the US AT27C512R chips in 28-pin DIP format are $2.80 apiece. Those chips are one-time programmable.
28-pin chips can be in multiple capacities, 512 kilobits (64 KB) being the biggest.
If the video BIOS is smaller than that, it's best practice to concatenate multiple copies of it to fill the whole chip.
The TL-866 II is popular and works, I don't know if it is any different than what you have proposed.
Reply 2 of 12, by badmojo
Thanks for the reply! Based on the BIOS file from the VGA museum the BIOS is 32KB, so I'm assuming this would be AT27C256R like this would be OK?
https://au.mouser.com/ProductDetail/Microchip … q%2FqQ69Oz0uUwJ
Reply 4 of 12, by badmojo
maxtherabbit wrote on 2021-11-14, 03:40:
Yeah that's perfect. Just bare in mind it's a one time programmable chip. So don't fuck up your settings in the programmer software
Don't worry I never make mistakes 😂
I'd better buy a few chips.
Thanks very much for the help guys 👍
Reply 5 of 12, by retardware
badmojo wrote on 2021-11-14, 04:05:
Or consider using EPROMs (UV Erasable PROMs) or EEPROMs (electrically erasable PROMs) instead of OTPROMs (one-time programmable ROMs).
If you have a stash of defective or otherwise worthless boards/cards, then it is highly likely that one or more of these have such a thing which can be reused.
Reply 8 of 12, by badmojo
Nemo1985 wrote on 2021-11-14, 09:44:
That's very interesting, are you willing to share both bios?
Sure I'm happy to share them if I get that far - I've ordered the unit so I'll see how I go.
Don't get me wrong the performance difference is tiny, but it's measurable and therefore enough to keep me up at night 😋
Reply 9 of 12, by Nemo1985
badmojo wrote on 2021-11-14, 11:12:
And that's because interesting. 😀
Anyway to make a dump of the bios you do not need anything special, with nssi, it makes the dump from the running pc. No programmer neded.
Thank you kindly.
Reply 10 of 12, by jesolo
Nemo1985 wrote on 2021-11-14, 11:30:
And that's because interesting. :) Anyway to make a dump of the bios you do not need anything special, with nssi, it makes the d […]
Thank you kindly.
Agreed. I would suggest that your temporarily disable Mainboard BIOS & Video card BIOS shadowing in the CMOS setup before dumping the BIOS with NSSI.
Reply 12 of 12, by Tiido
Some cards also have shuffled bit and/or address order, Trident ones for example.
