how tough is 286 processor
First post, by kohellus@gmail.com
Hello,
Got a 286 motherboard, baby at. Was somewhat corroded from a varta.Cleaned ok but some traces are dark in some spots.
Was wondering if you put the processor in a PLCC socket couple times the wrong way. Is the processor tough enough to survive and finally when its the right way its heating up quite alot.
It was sold as dead but it was also missing an oscillator so i thought maybe thats the problem, untill i went cleaning the corrosion and putting the cpu backwards, it stayed cool when it was backwards and 5v goes to memory and cpu and the oscillator, isa slot too but it doesnt even beeb. Cpu gets hot when in correct orientation.
Can a 286 cpu survive few times backwards insertion? I know thats not supposed to happen but when you are excited enough 😀
Regards Mika
Reply 2 of 24, by majestyk
In some cases there´s a forced shorting of the core-voltage with ground when the chip is inserted the wrong way, so the PSU just won´t start up and no damage is done.
I have no idea if that´s the case here.
Reply 3 of 24, by BitWrangler
Well I heard a 286-16 kicked Chuck Norris's butt at Battle Chess once, but electrically, I dunno, not quite as tweaky as later CMOS so if it didn't let out the magic smoke, you might have a shot.
Reply 4 of 24, by Caluser2000
BitWrangler wrote on 2021-11-19, 18:18:
WOW! That is AMaZInG!. Who'd a thought the brain dead cpu could do that ah.
Reply 5 of 24, by cyclone3d
Caluser2000 wrote on 2021-11-19, 18:39:
CPU has nothing to do with it... It would have been the Chess program logic.
Other than how long it takes the CPU to be able to execute the code, and thus "decide" the moves, there is no real advantage for faster CPUs except that the human opponent may have more time to think about their next moves.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 24, by Caluser2000
cyclone3d wrote on 2021-11-19, 19:35:
You really don't have a sense of humor do you Big Rooster?
I suggest you pop down to the $2 store and buy some 😉.
Reply 8 of 24, by Caluser2000
i fitted a TurboChip x586 cpu in the wrong in a 486 and it didn't post. I turned the system of and fitted the x586 cpu the correct way around and it booted right up. Appeared to be slower than the 486DX2/66 it was ment to replaced. I suspect I killed the L1 cache on the x586 cpu.
Reply 9 of 24, by Anonymous Coward
I've put CPUs in the wrong way before. I guess it depends which way you put them in. Some wrong ways will kill it and others not. I've managed to shatter one PGA, and pop two plastic package CPUs with the wrong orientation. But, I've also had CPUs put in the wrong direction which simply didn't POST and worked normally afterward.
For older 286 CPUs using NMOS technology, getting really damn hot is normal. It it's 12MHz or faster it's likely CMOS and should run a bit cooler.
I'd have to see your board to tell you if the missing oscillator or crystal is causing problems. 286s usually use at least two of them, sometimes more. You have one for the main system clock, and one for the OSC signal used by some ISA cards and other parts of the motherboard. These two are the most important, so if you're missing these then the system likely won't turn on. If the missing oscillator is for running the NPU in async mode, then it shouldn't make a difference. There are also some boards that use yet another oscillator for the ISA clock if run in async mode. Those are usually soldered in place though.
Reply 10 of 24, by Nexxen
I made a mistake and put a 80186 in a 286 socket.
Wasn't booting so I tried a second time.
Board was fine, cpu I have no 186 board to test it in.
No smoke, just hot but not enough to remove my finger (around 45°C).
The other 286s were hot but like above.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 11 of 24, by Tiido
NMOS 286 get really toasty in normal operation, CMOS ones are much less hot but still hot enough that I would not consider running them without a heatsink.
I have not had a 286 put into the socket wrong way so I don't know what are the odds of it surviving such a stunt but probably pretty low.
Reply 12 of 24, by retardware
Do this with 4116 ( 3 supply voltages!) please please.
In my youth I did this several times, and if I remember correctly, Hitachi chips were outstanding... if the chip survived, it was usually a Hitachi.
Reply 13 of 24, by maxtherabbit
Anonymous Coward wrote on 2021-11-20, 11:56:
how do you manage to keep fucking that up over and over 🤣
need glasses?
Reply 14 of 24, by Anonymous Coward
Nope. Drinking on the job.
Considering I only killed 3 CPUs (actually 2 CPUs and one FPU) over the course of 25-30 years, I'd say my track record isn't too bad.
You have to keep in mind this was back in the olden days when stuff was free or really cheap.
Reply 15 of 24, by cyclone3d
Caluser2000 wrote on 2021-11-20, 01:50:
Hah! I wasn't sure if it was meant to be funny or not.
YMF7x4 Guide
Reply 16 of 24, by kohellus@gmail.com
Hah, good humor there. I did write an answer before but i guess it went somewhere. Here's a pic of the mobo and i did put a 24mhz crystall in it for a 12mhz processor but nothing is alive. Anyone has a 12 or 20 mhz processor in need of a job 😀
https://ibb.co/3spnsWC
Reply 17 of 24, by retardware
kohellus@gmail.com wrote on 2021-11-20, 16:42:
... i did put a 24mhz crystall in it for a 12mhz processor but nothing is alive. ...
Always upclock in small increments... eg 12, 14, 16, 18, 20, ... and watch chip temperatures and do some stability tests before you decide that the next step could still be functional.
In my experience it is usually not the processor but the chipset which dies first by a clock too high.
Reply 18 of 24, by Nexxen
If you have an analyzer card put it in a see if you get any code.
BIOS could be dead, can you flash a generic 286 bios? (anyone help here pls)
Are psu voltages in range?
Reply 19 of 24, by Horun
This appears to be same board: https://www.ultimateretro.net/en/motherboards/5196
Make sure you use 256k or 1Mb 9chip 30pin simms, most 3 chip do not work or are unstable on 286 boards from my experience....
And Yes you can kill a 286 by putting it in sideways, backwards, any way but proper.
And yes 286 16Mhz and above can get very hot, specially the AMD 16Mhz ones (Harris are cmos and run cooler)
