Reply 500 of 600, by bloodem
Leaving this here: https://www.youtube.com/watch?v=CCqxE-5Ct3w&t=503s
My experience with thermal paste of above average quality has always been very good - no matter if it dries out or not.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 501 of 600, by feipoa
Pardon my late arrival to this thread, but I couldn't help but wonder if anyone knows the rationale for disabling half the cache on the K6-2+ chips? With the Pentium Pro chips, I'm pretty sure that the difference between 256k, 512k, and 1024K was the presence of less cache, and consequently less manufacturing cost. For the K6 chips, was it just that the cost difference between 128k and 256k was less than the cost to have a dye with two cache sizes?
Reply 502 of 600, by Sphere478
feipoa wrote on 2022-06-06, 05:48:
The pentium pro used separate dies for the cache and core.
I assume the reason for the k6 2+\3+ was partially to increase yields by pushing ones with partially damaged cache to market with part disabled, as we have seen this is the case on some, but as well to also give several options as to capture more price points. Kinda like pentium vs celeron. We have obviously seen that there were many with good cache that also got the cut.
Sphere's PCB projects.
Reply 503 of 600, by elcrys
First a little teaser:
7.71 KiB
Then a full story:
About a month ago, a batch of three AMD K6-2+ 570 MHz (570ACZ) from a well known seller finally arrived. I prepared my trusty Gigabyte GA-5AA (cache stable at 115 MHz FSB), nice cooler with a copper core and began. First I quickly confirmed that each is capable of 600 MHz @ 2.0V - this was no problem. Then I set 2.2V to check maximal OC potential. One of the CPUs (#3) was able to load Windows at 690 MHz and seemed stable:
14.84 KiB
6.31 KiB
Unfortunately Prime95 quickly showed an instability. At that point I said "OK, let's see, what 2.4V can do!". With this voltage I didn't want to torture this CPU in Prime, so I just tried how far can I go. At 720 MHz (6x120 with disabled L3), computer went through POST, but even DOS applications were crashing. As a final resort I tried combination 700 MHz (5x140 with disabled L3) which seemed stable in DOS and this is where I took this:
7.71 KiB
But Windows was a no-go. Funny thing is, I confirmed later that 140 MHz FSB is unstable even without cache, so for 700 MHz Windows "experience" I would need a better board.
Finally I wanted to check how far can I go at a standard 2.0V. To my great surprise it was 660 MHz (6x110):
35.97 KiB
Reply 504 of 600, by elcrys
Yesterday, I finally decided to go with the mod for the best CPU (#3) in the batch. After de-lidding, some cleaning (btw. plastic eraser is great for scrubbing the remnants of TIM from CPU) and de/re-soldering of the link (here I am not sure if it's a 0 Ohm link or a capacitor because my measurement showed 32 pF of capacity) the deed was finally done (sorry, no time for cleaning 😀):
268.32 KiB
I didn't want to waste time with re-attaching of heatspreader so I went ahead carefully with on die cooling. During the first POST, I was holding my breath, but there were no cache errors! Then I used memtest as per guide to test the cache properly and everything was OK. After that I basically confirmed what I have tested before: 700 MHz @ 2.4V is still highly unstable (as I wrote, here I would blame the board), 690 MHz @ 2.2V is still Prime95 unstable, but more importantly 660 MHz @ 2.0V is still stable. I went as far as to lower the voltage to 1.9V and it still managed to do over an hour of Prime95 without any issue:
36.51 KiB
In any case, the mod was a success, thanks to Sphere478 for discovering it.
A few more pictures of unstable 690 MHz @ 2.2V:
14.74 KiB
6.48 KiB
21.43 KiB
Reply 505 of 600, by Sphere478
Excellent results!!! :p
Reply 506 of 600, by Sphere478
Fritzchens Fritz wrote on 2022-03-06, 02:43:
Today I moved the upper left resistor. The L2 cache was completely disabled and the CPUid got the number 5C8 (it's a Chomper XT now) 😀
You know, someone should see if they can enable the cache using central tweaking unit after disabling it via resistor.
Reply 508 of 600, by debs3759
ChrisK wrote on 2022-07-19, 17:08:
First modified ones pop up on eBay: 165583247664
Who was it? 😉
Sphere's been selling them for a while (I want to say a few months?)
Reply 509 of 600, by Sphere478
I don’t have any up atm, so that’s not me. but I still have a few.
Reply 510 of 600, by Sphere478
I just messaged the ebay user. They are nice. We are already nerding out over retro stuff. They have quite a nice retro collection.
I just learned that someone made a youtube vid for this mod? Has that been posted already? Anyone know where that is?
Reply 511 of 600, by bloodem
bloodem wrote on 2022-04-13, 14:43:
I recorded this almost a month ago, finally managed to upload the video today: https://www.youtube.com/watch?v=5Aw2U_BZnSk
It's a guide with the method I'm using for modding the K6-2+ to a K6-3+, maybe it will help others.
Probably mine? I wrote about it 3 months ago on this exact thread (see quote above), but I'm guessing you missed it. 😀
Reply 512 of 600, by Sphere478
bloodem wrote on 2022-07-19, 18:42:
If
I noticed it, I forgot. 🤣.
I’m going to add it to the guide on page 13 thank you 😀
Reply 513 of 600, by bloodem
Sphere478 wrote on 2022-07-19, 18:49:
Great, you're welcome! 😀
Reply 514 of 600, by ChrisK
debs3759 wrote on 2022-07-19, 17:25:
Who was it? 😉
Huh? Was there an official announcement here? Must have missed that if so.
Not browsing ebay very often lately, have just seen this offer by chance.
Reply 515 of 600, by Sphere478
I haven’t announced/advertised here. Didn’t know if it was allowed.
Reply 517 of 600, by Yekg01
Anyone fancy the read deal 🤣 or having a go at modding this one?
Are new chips more likely to overstock better than older ones?
Ebay delivers again..Ive got my eye on this one !
https://www.ebay.co.uk/itm/265796601542?mkcid … emis&media=COPY
Reply 518 of 600, by Sphere478
Yekg01 wrote on 2022-07-27, 19:27:
Anyone fancy the read deal 🤣 or having a go at modding this one? […]
There is nothing to mod on that
You know what, I don’t think those overclock any better than modded 570s
