I have four.....
My #1 for the big monster 486 XT Desktop is a 17" Dell CRT from 1998-ish. IT's sharp, it's crisp, it's bright, and it's easy for my worn nearly 39 year old eyes to read. And I got it for free.
The VersaDock uses some other generic CRT of which the brand name escapes me, I think it has "Vision" in the name. 15", SVGA, also bright and crisp, also free.
My NEC Ready 9522 tower came with a Micron CRT from 2001 with digital controls, 14" SVGA, yellow as pee, also has some strange staining on top either from someone's red wine glass or some other beverage or tinted candle or somesuch. Not too surprising since it's the grandmother of the original owners. Right now that one might end up being the CRT for my PCChips 486 system.
And lastly is my most prized find for free, a NEC MultiSync II JC-1402HWA, a 14" 15KHz capable CRT monitor that I found for free at Computer Recycle in Redmond WA. It was sitting face down in the "recycle" pile and they just let me have it. Turns out the PCB was cracked (as usual) so I bodge wired it back together and now it usually sees use with my Tandy 1000A, probably the crispest thing for CGA because it also works as a TTL Mono, Hercules, EGA, VGA, and SVGA Monitor. I also managed to eek out 1024x768 from it once, and I've read it works with other systems as well with different adapters.
