First post, by FFXIhealer
Has anyone ever tried to use a brand new SATA DVD drive using a SATA-to-IDE adapter successfully in Windows 95/98?
I'm asking because of "failing drives" or the like. It could very well be the capacitors on my motherboard need to be replaced, but if the drive itself is proven to be failing, I wonder how a SATA optical drive would work using one of those IDE converters plugged into the back on these older systems.
Discuss!
