Look at socket 8, it had the first Pentium 2 on it as a Pentium II overdrive, it worked fine but Intel being Intel saw a way to remove AMD and others from its platform, the slot1 based design which thanks to the chipset was locked to Intel CPUs and Intel refused to share it with AMD, AMD went and did their own slot format in slot A but from that point on the two never again used the same socket or platform, I cant say for sure if that was a good or bad thing but it certainly hasn't done either of them any harm.
I own a Pentium II overdrive, its not huge or incapable of being cooled and aside from the socket 8 platform only ever seeing major use in server boards it works perfectly fine.
The one thing I would have loved to see on the Slot connector was through board retention with a backplate, a way to take stress off the connector itself and apply it to the supporting structure which would have been stronger and not connected to the board by weak solder joints. As for damaging slots .. seen that way to many times with AGP and PCIe GPUs when people use a little to much lateral force and snap the slot right off the board or use to much force when removing it because they failed to unlock it which ends up tearing the slot off the board.
Slots by their very nature are more fragile than sockets.
PEBCAK exists and should be respected.
Im crazy not stupid, well not stupid enough to make claims that are total nonsense.
