First post, by vstrakh
Got this board, it's not detected by bios.
962.22 KiB
Probing the power lines I see some suspiciously low resistance (88 Ohms, or 0.17v drop when measuring in diode testing mode).
It's not dead short, but still way too low. To avoid desoldering all tantalum capacitors I started with taking out all the socketed chips.
It turns out the dead IC is the PAL16L8 close to ISA connector, the one in row with 74LS244 buffers.
I think I would be able to replace it with modern GAL16V8 from Microchip, but I'd need the equations from the original chip. The original PAL is of L series, so just plain logic, no registers, and I think it would be relatively simple to probe the behavior of the original working chip. Or maybe I could reverse-engineer that piece if I had a schematics for that card.
Does anyone has this card and would it be possible to read/probe its content, or at least any hints on where to look for the board schematics?
Reply 1 of 5, by Jo22
Hi! I've found some information about the chipset a while ago.
See OAK OTI-037c - 800x600 mode ?
Maybe it is partially helpful.
Good luck! ^^
Reply 2 of 5, by vstrakh
Yeah, I've seen the datasheet for OTI-37c.
Problem is - there are many cards built on this chip, and the PAL is typically used in glue logic around the chipset, implementing decoding of address and other control lines logic.
This varies wildly between cards, and the equations in this dead PAL are specific to the exact board and revision.
Meh, will return to this board later...
Reply 3 of 5, by vstrakh
Seems I have a bit of luck with reverse engineering approach.
The dead PAL is only involved in generating IOR#, IOW#, ASEL and RESET signals for the OTI-37c, so basically only detects the addressing of VGA memory area and distinguishes I/O ports access from DMA transfers and refresh conditions. It's not involved in other onboard details, like the timings, data flow orchestration or BIOS chips mapping onto the bus. All the signals are coming directly from the ISA edge connector, and outputs are going into oti-037 directly or through 7404 inverter.
So I hope it would be just some looking into ISA specs and a bit of head scratching to map the i/o access logic.
I'm not sure yet if IOR#/IOW# are depending on the address lines or oti-037c filters addresses on its own. The datasheet did not include typical application schematics and the block diagram does not include needed details.
Googling around I see that ISA cards often/typically only decoded 1K of I/O address space, and not full 64K.
This matches well the A9-A4 lines I see on that PLA, so the answer should be "decode the addresses yourself on that PLA".
Reply 4 of 5, by vstrakh
Here's the pinout of that PAL design.
16.57 KiB
Wrote the PLD design that decodes I/O ports access signals and VGA memory areas. It all looks ok in simulation, but still didn't bring up the card to life.
It's possible some other ICs are not ok, so I'd need a full-blown debugging on a breadboard (don't want to risk the motherboard's health).
Ordered some ISA edge connectors from Aliexpress...
PS: I know the card is garbage, it has only 8-bit data path to the video memory. I'm just kinda enjoying diving deeper in old hw, brings up memories 😀
Reply 5 of 5, by Jo22
vstrakh wrote on 2022-01-25, 09:18:
Seems to match my memories, too.
8-Bit ISA (PC Bus) mirrored so many addresses due to flawed / cheap decoding circuits.
Speaking of these, did you know that IBM CGA technically was able to do 640x200 in 4 colours, too? Not just black/white?
- If the address decoding wasn't so flawed.
CGA used merely 16 Kilobytes of its 32KB frame, also, if memory serves.
The other half was a copy/repeated memory pattern..
But I'm speaking under correction here. Please double-check my statements. 😀
Also, the dithering of CGA was/is cool. A simple mode-switch and.. Voila! Your 320x200 4c image becomes a nicely dithered 640x200 b/w image. 😀
That being said, the many mirror copies had its place. It just was a tiny bit frustrating to 286/PC-AT users. 😉
The PC AT platform had a huge 16MB address space (ISA..), but only a handful of i/o ports due to backwards compatibility.
And memory-mapped devices, like Weitek Abacus, were 386+ stuff.
vstrakh wrote on 2022-01-26, 09:22:
Here's the pinout of that PAL design. u12_pinout.PNG […]
No problem. The contrary is the case. You're doing it completely right, imho. Kudos. 😎👍
