First post, by squelch41
Hi,
Doesn anyone know which (e)eproms that 3com 3c905B-TXNM network cards support?
Want to use one for XT-IDE but it seems that the AT28C256 doesnt work but it may be I have it configured wrongly.
The eprom works fine in one of my other network cards so the rom is ok.
The 3com has a 32 pin socket. The ROM socket is enabled in the card config program.
The manual just talks about "boot roms" but never specifies exactly which chips are compatible!
Thanks!
V4P895P3 VLB Motherboard AMD 486 133MHz
64mb RAM, CF 4Gb HDD,
Realtek 8019 ethernet + XT-IDE bios ROM, ES1869 soundcard, VLB Cirrus Logic GD5428 1mb VGA
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
