Does that SD to CF card converter/adapter card have "True IDE Mode" implemented ?
From what I remember, that's not the only mode of the real CF cards.
CompactFlash cards also usually supports programmed i/o mode and memory-mapped mode.
They're used for digital cameras or card readers, I assume.
The famous IDE mode was originally intended for industrial CF cards, so they can be used as drop-in solid-state storage in PC-based controllers, ATMs etc. way back in the early 90s.
At the time, there were memory cards for PCMCIA (PC Card) bus around and CF cards could substitute them with the help of a CF to PCMCIA adapter card.
(PCMCIA was considered a bringer of hope that would be an universal standard for both PCs and laptops or even a successor to ISA/PCI bus, but it never catched on.)
Anyway, this was a bit beforey time.
Back then, Amigas were still being sold and CF cards weren't really consumer products yet.
They were expensive and small in capacity.
Early Compact Flash cards had 2MB, 4MB, 8MB or a whoopin' 16MB..
Edit: Another question.. How old is that SD to CF converter?
Does it explicitly support SDHC or SDXC?
I'm asking, because old SD devices from the 2000s do not support SD cards larger than 2GB or, in rare cases, 4GB..
Strictly speaking, SDHC or SDXC cards are no real "SD" cards. Real SD cards are 2GB or less.
Edit: Here' an older thread of mine. It might not be entirely accurate, because I'm just a layman, but it might contain bits of useful information.
4GB SD cards may not work in SDHC devices
Edit: And then there's MMC, the Multi Media Card.
It's the step sister of the SD card. Some SD devices may really just using MMC features.
