First post, by cyberluke
Hi, can you give advice on where to get some small power supply board that would fit this case?
https://aukro.cz/minidesktop-pc-tulip-386sx-2 … -fdd-7006312688
It could be also atx. The case could be 3d printed and fan could be added, so the board itself could be enough. Cannot find the original one, so looking for alternatives now.
Reply 1 of 4, by BitWrangler
You might want this board ATX to AT pico Adapter! + Fan Headers, -5v, and 3.3v (Released) and a Pico ATX unit that converts an input voltage to PC voltages (Get from eBay or Amazon, Ali Express etc) which will require an external 12V power brick or laptop supply.
However, there might be some older "1U" blade server PSUs that are suitable, before they went to single 12V supply.
Reply 3 of 4, by weedeewee
considering the formfactor,
get yourself an AT to ATX PSU cable and a Pico ATX PSU,
since the AT pico adapter wont work for you.
Do not ask Why !
Reply 4 of 4, by Cuttoon
weedeewee wrote on 2022-03-11, 12:37:
considering the formfactor, get yourself an AT to ATX PSU cable and a Pico ATX PSU, since the AT pico adapter wont work for y […]
I second that - no use looking for the original and a pico ATX with adapter should do just fine.
Wow, that tiny 386 is cute!
*looking up koruna-euro exchange rate*
I like jumpers.
