First post, by brian105
I'm looking to buy the next fastest Athlon 64 x2 because the 6400+ is basically unobtanium. I understand that the Brisbane core 6000+ has half the L2 cache and as a result is slower, but there is apparently another low-power SKU of the 6000+ (ADA6000IAA6CZ) vs the standard 125w part (ADX6000IAA6CZ). They also have different steppings listed here:
https://www.cpu-world.com/CPUs/K8/AMD-A ... ZBOX).html
I can't find documentation on whether they perform differently, so if someone knows the difference, please tell me before I buy the worse part. Thanks in advance.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 1 of 5, by Meatball
My understanding is the 89w is more energy efficient and compatible with a wider selection of motherboards due to the lower power requirements. I presume the 125w will overclock better. Otherwise, they are the same.
Reply 2 of 5, by brian105
Would the 89w not overclock better on the basis of running a lower voltage by default?
Reply 4 of 5, by Meatball
brian105 wrote on 2022-04-15, 00:49:
You're probably right. I was looking at the 125w and only thinking "more power, more fast" Toolman, style.
Reply 5 of 5, by brian105
Thanks for the advice, bought the 89w part. (from China ofc, time to wait 14 years)
