First post, by kikendo
I got one of these and I cannot figure out how to open it, and afraid of breaking it, I ask for the community's help.
It's the one in the photo. I can't find pry points or screws.
943.61 KiB
901.28 KiB
Reply 1 of 10, by weedeewee
One or two screws under the half circle glide pad
Can't remember if there's a screw under the line glide pad.
Do not ask Why !
Reply 2 of 10, by Horun
Yes should be screw or screws under the half circle pad, most have tabs near the cord IIRC so when you unscrew, gently lift top at an angle from the screw side or else you could break the tabs.
Reply 4 of 10, by kikendo
Well I found the screws and they were NOT under the half circle pad, but under the model sticker. That's all sticky things removed, I hope I can replace them 🙁
Now the problem is, I cleaned this as much as I can, but I still get a jumpy cursor when I go too fast. Works well when going slow.
The innards look like this:
628.46 KiB
I never quite seen a mouse like this so I have no idea what to do. Seems like the diodes are inside those potentiometer-looking packages.
I blew air in them (you can remove the black back) and used some contact cleaner fluid too, but they still work the same way. I cannot physically reach the leds, without destroying the package.
Could it be something else causing this issue?
Reply 5 of 10, by Horun
Thanks for the info ! Does it jump in both serial and ps2 modes ?
Reply 6 of 10, by kikendo
Horun wrote on 2022-06-12, 23:55:
Interesting. I don't have a serial to PS/2 adapter, so I cannot know if it does it in serial mode only.
Also, I should try it in another computer too, while we're at it.
Reply 8 of 10, by Plasma
What do you mean by "jumpy cursor"? If the cursor moves in the correct direction, but with larger steps when you move it quickly, that's normal for a serial mouse due to the slower update rate. It will seem choppy compared to a USB mouse.
Reply 9 of 10, by kikendo
Plasma wrote on 2022-06-15, 23:07:
I meant that if you're moving to the right, it will go left every now and then. How much left, depends on how fast I move it. that's "jumpy".
I tried it in another machine and it seemed to work fine. maybe it was a computer problem on the serial port?
Reply 10 of 10, by weedeewee
What computer and what software are you using when the mouse sometimes does this jumpy behaviour ?
Do not ask Why !
