First post, by Harlock
Hi, I recently noticed a weird noise, loud but not THAT loud, coming from the CPU fan if my Pentium 166 MMX.
I'm currently using a heatsink and a fan on top.
Could you guys recommend what kind of fan/heatsink should I go for since I want to replace it?
Would any socket 7 be fine? Or any other compatible?
Reply 2 of 8, by smoke86
Romain wrote on 2022-09-15, 18:34:
You can repair it by complete fan disassembly, deep cleaning, oil (I recommend the car oil 5W30 - forget the too fine oils that evaporate with the slightest heat) and reassembling.
I would recommend the same solution, but after dismounting a fan, make sure to give its axle a healthy dose of WD40 just to clean it. After it evaporates, apply said motor oil or silicone oil. If the fan is significantly worn, you may apply white lithium grease (in form of spray) to its axle.
Reply 3 of 8, by Sphere478
Any old socket 7 heatsink should do.
Some 370 and socket a heatsinks may work. But try and see.
In general try to avoid the super high tension clips though.
Sphere's PCB projects.
Reply 4 of 8, by Repo Man11
I have a Socket 7 cooler that I replaced the worn out fifty millimeter fan with one of these: https://www.amazon.com/Gelid-Solutions-Silent … n/dp/B008S1DN66
Reply 5 of 8, by Shponglefan
Assuming you have a standard Socket 7 heatsink, you can just replace the fan and reuse the existing heatsink.
I've been using Noctua fans for CPU cooling on older systems: https://noctua.at/en/products/fan
They're extremely quiet, and they have a variety including 60mm which is perfect for older CPU coolers.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 6 of 8, by brian105
Repo Man11 wrote on 2022-09-15, 20:59:
Can recommend this one too, I use it on my K6-2+. Very quiet.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 7 of 8, by Harlock
Shponglefan wrote on 2022-09-15, 21:20:
Yes, that was my idea eventually, just replace the fa.
Anyways, thank you all for your suggestion, if I get some spare time I might try to disassemble the thing, otherwise one of those fans above look like a feasible option.
Reply 8 of 8, by NostalgicAslinger
Is use this Cooler Master Socket 370 cooler for my Pentium MMX 233 system. Runs fine since four year.
