First post, by haker120
I just got s370 to slot1 adapter without manual and I have no idea how to set it up. Pics of adapter in attachement.
    185.09 KiB
Reply 2 of 11, by Sphere478
For setting vcore 😀 setting will vary by cpu.
🤔looks like it doesn’t make the voltage its self, but rather the jumpers send the request to the mobo.
Sphere's PCB projects.
Reply 4 of 11, by PARKE
Ok, in your case the print is absent. But this is the QDI 3.0 (S3.1) slotket and the settings in the photo above should work.
322.63 KiB
Reply 5 of 11, by haker120
They do however P3 doesn't work and only Celeron I own is 1.1GHz and I'm not sure that will work. And before I'll confuse anyone, I did set 1.8V as this is the minimum my board accepts. 😀 Works with my other modified slocket1 at 1.8V.
Reply 6 of 11, by aaron158
haker120 wrote on 2022-12-08, 18:03:
what p3 did u use. if its 440bx its best to use one that does 100mhz fsb. also is the bios updated
