First post, by Horun
- l33t++
The 1000mf 6.3v caps on two boards need replacing, one is Soyo 6BA+ III (with 11) the other is a QDI 7x/600 (with 15). Both use 8mm diameter (~ 3mm lead space) but the Soyo are ~11mm tall and the QDI are 14mm tall.
There are no real height restrictions on either board where they are located and want to use same caps on both if possible to simplify the order.
These Rubicons: https://www.digikey.com/en/products/detail/ru … M8X11-5/3563358 would work fine AFAIK.
Any feedback greatly appreciated. Thanks !
