First post, by ubertrout
I was recently gifted a used 1.2 M (I assume) 5.25 floppy drive, which I plan to use pretty much exclusively for archival data recovery. My main thought was to put it in my Dell Dimension V350, which is of the vintage where I'd think it would work, but I don't know if the floppy controller supports two drives and/or 5.25 drives at all. I also have a Asus P5Q based system running WinXP, which has a floppy controller (and a working 1.44 drive) but I assume is far too new for a 1.2M drive. Final option is to get a Greaseweazle and play with that on a modern system. What do people think?
