First post, by guitarbloke
I can't for the life of me get any CD drive working under DOS (win98). It works fine in Windows.
The drive is an LG CD/RW/DVD-ROM (GCC-4520B)
I've been trying with several different drivers but all I get is a flashing cursor and no prompt on startup. If I remove the CD driver lines, it boots fine into DOS.
Can anyone steer me in the right direction please?
Autoexec:
@ECHO OFF
PROMPT $P$G
PATH=C:\; C:\CDROM; C:\WINDOWS; C:\WINDOWS\COMMAND
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:MSCD000
SETBLASTER=A220 I5 D1 T4
C:\SETUPSA.EXE /S
C:\WINDOWS\COMMAND\MOUSE.COM /Y
Config.sys:
DOS=HIGH,UMB
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\CDROM\OAKCDROM.SYS /D:MSCD000
Reply 1 of 8, by Ryccardo
guitarbloke wrote on 2023-01-29, 17:48:
DOS=HIGH,UMB
IIRC you need an UMA driver to load high anything (ie, they screwed up the name of that command, it's not actually using high memory but upper memory... and the former is technically part of the latter except that practically it's not)
Unrelated, but not sure if this is one of the cases where you can skip the space after the name of the command?
Good luck!
Reply 2 of 8, by Horun
try mscd001 not mscd000 like in this post Re: Need some DOS optical drive help
Ryccardo wrote on 2023-01-29, 19:06:
Good luck!
Correct should be: Set blaster=
Reply 4 of 8, by CoffeeOne
guitarbloke wrote on 2023-01-29, 20:38:
Thanks @Ryccardo and @Horun - I'll change that!
Any ideas on getting the cdrom working?
Hmm.
Could you tell us the output of the commands?
Interesting is this (config.sys comes first):
I assume here is a problem
and then from autoexec this one (which only works, when the device was loaded before in config.sys of course!)
Reply 5 of 8, by LSS10999
Where did the system hang occur when you have the CD driver line (OAKCDROM) active? Was it OAKCDROM itself, or at some point later?
By the way, what motherboard are you using? Depending on your system/chipset configurations some CD-ROM drivers may or may not work.
LH shouldn't be a problem. If no upper memory then the TSR in question will stay resident in conventional memory.
EDIT: Did you try other CD-ROM drivers? I think in your case you may try VIDE-CDD to see if that will work for you.
Reply 6 of 8, by Jo22
Does MSCD000 work as a device name, at all ? I always assumed MSCD001 was the default.
Reply 7 of 8, by paradigital
Jo22 wrote on 2023-01-30, 16:56:
Pretty sure that’s just a string, the number isn’t an integer and isn’t checked. You can call it whatever you like, so long as you are calling it the same thing in config.sys and autoexec.bat.
Hence why in most boot disks it’s called “BANANA”. You could call it Zaphod if you liked.
Reply 8 of 8, by Jo22
paradigital wrote on 2023-01-30, 17:05:
Sure, makes sense. But on the other hand.. This is DOS.
The same DOS in which silly applications used "D:" as a hardcoded location for a CD-ROM.
That DOS in which applications checked diskettes by the presence of empty files ("DISK1.", "DISK2.") rather than the label string.
Or worse (?), used a single "DISK ." file on each floppy that had another content ("DISKETTE1", DISKETTE2") each time.
This made it very tricky to use a software installer from a single HDD directory.
So I would always use the official names or known conventions, not "DINGDONG", "$EXDRIVE" or "BAZOOKA". 😁
