First post, by BitWrangler
- l33t++
Hi Vogons,
Seen some passing references of the "maybe I've heard of it" type mentioned years back on this forum. But can anyone confirm or deny the existance of a software emulator of 387 or other version x87 functions on Weitek hardware? Presumably being faster than emulators that run purely on integer hardware.
Y'all probably seen me referring to x87s as "dust caps for the socket" or 387s making your 386 fast enough to be too slow to play quake, so are wondering why I'm bothering. Well FPU for non-technical uses came into it's own at the upper end of 486 into Pentium levels of performance, which is where I have a fringe use case and would like some FPU support, but as you may know, a 487 ain't it. I do have boards with a 4167 hole, that could potentially support the integer only CPU in question.
Asking because I've got a shot at getting a 4167, and this is the only possible use I would have for one at all... I can tape over sockets to keep dust out if it bugs me.
TIA for any hints
