First post, by _tk
I was given a Dell SFF PC that has the Intel i845 (PC133 RAM) and it came with a Willamette 478 1.7ghz processor in it. I'm likely going to fix it up for my son. I'm not a huge P4 fan and a lot of the upgrade paths I've long since forgotten, so what's the CPU range I can use in this? I know some early P4's are pretty cheap so might as well see what I can find.
I assume I can run a 2.0ghz Willamette or perhaps a slightly faster 400 MHz FSB Northwood. I'll assume the best of the bunch will be expensive, but something like a 2.4ghz should make a decent difference vs the 1.7ghz in there.
Hate the fact that I have to run a low profile AGP card so it looks like I'm stuck with either a Geforce 4 mx440 or a FX 5200. Neither are appealing but they should do what is need.
