First post, by Syntho
Something is bothering me. I have a weird, faint scan line thing going on on my monitor. It only happens in W95 with my Diamond Stealth S3 4mb Pro card. I'm using a CRT monitor. If you look closely you can see lines moving downward. It's kind of like recording a CRT screen but it doesn't look that bad.
I tried changing the refresh rate but it's only got Standard, Optimal and 60hz with no change. Funny that this doesn't happen on two other ISA cards I tried.
