Just an important heads up
Reply 302 of 325, by Qbix
Rank DOSBox Author
DOSBox Author
Dominus wrote:
Qbix are there restrictions in the DOSBox guide forum for editing posts for normal users? Truth5678 isn't able to edit the post I moved there Re: DOSBox and MIDI music
Yeah, I think that given the nature of the guides, that this isn't a bad restriction
Water flows down the stream
Reply 307 of 325, by Malik
Is it possible to post saved drafts directly back into the thread where it was saved from (via a button)? Either I don't know how to do it, or that functionality is not there. I could only view and edit my drafts. I guess I should just copy and paste?
Reply 308 of 325, by collector
It's not very intuitive, but after you click the "Load draft" button, the next screen it loads has a "Load draft" header that lists your saved drafts right below it. Just click on the draft title you want to load and it will load it in the message editor pane.
Reply 310 of 325, by Stiletto
To what god do I have to sacrifice to get image attachments to display embedded, inline? 😀
Re: Vital MF002BR 8-bit sound card
Preferably, I'd also like to have embedded images that are larger than the browser window auto-fit to width of window. I'm currently limited to a 1366x768 display and frequently recently embedded images (attached or not) are larger than that and force me to scroll.
do the Fandango!" - Queen
Stiletto
Reply 312 of 325, by Stiletto
collector wrote:
Are you just linking to it using the [img] tag or are you adding the image file as an attachment?
The second. Did you look at my post? 😀
The first time I wrote the post, I embedded images from another site. Then I decided the site could always go down, and thus removed the embed and added them as attachments.
Still, "View inline" should view inline, if the forum software understands them.
Stiletto
Reply 313 of 325, by collector
Odd. This is not normal behavior for phpBB3.
test:
180.21 KiB
No downloads
Edit: I tried it on SHP and it does display: http://sierrahelp.com/forums/viewtopic.php?f=2&t=3935 It must be some setting in the Administrator's Control Panel, which I haven't had access to since it was moved from the test board.
Reply 314 of 325, by Stiletto
collector wrote:
Odd. This is not normal behavior for phpBB3. […]
test:
Dear Qbix,
Please fix when you can.
Happy Easter,
Stiletto 😀
PS. Qbix, any idea why - as a moderator - I could not fix this formatting in kithylin's 2011 post earlier?
I saw it - it annoyed me - I tried over and over to fix. I could only get it to work in a new post.
Something weird with the forum import?
Re: Rendition Verite in pure dos help please?
Stiletto
Reply 316 of 325, by gandhig
Stiletto wrote:
The second. Did you look at my post? :) […]
collector wrote:
Are you just linking to it using the tag or are you adding the image file as an attachment? […]
Are you just linking to it using the file.php?mode=view&id=14451&sid=df1e65df6cb979e4335f911aeb6f5fbe
Yeah 'place inline' is misleading. Maybe that's why they didn't call it as 'view inline'.
Alternatively, I upload the image and copy the link address and use the 'Img' option instead of 'attachment' for embedded display like below. Hope this is what is being discussed.
    180.21 KiB
    No downloads
Dosbox SVN r4019 + savestates Build (Alpha)
1st thread & the only one related to the forum(?)...warning about modern-retro combo
Dead, but, Personal Favourite
Replacement for Candy Crush...Train the Brain
Reply 317 of 325, by collector
But it works as expected on other phpBB boards, including this board before the upgrade. And the reason that Stiletto wants to embed the image instead of linking to it is to preserve the image in the thread, even if any other site goes down. One of the most valuable things about VOGONS is that it is a huge, growing, searchable database, not just a place to gab. This board goes back for more than a decade. How many other sites have come and gone in the mean time?
Reply 318 of 325, by gandhig
I misunderstood the 'embed' part. If it was felt that i was gabbing or something like that, then I'm sorry. That wasn't my intention and I will think twice before posting from now onwards. I do really appreciate the knowledge transfers going on in our forum and the efforts put by older members.
Just for the sake of curiosity, If I upload an attachment, will it go to the Vogons forum server(and will be stored permanently there) or to some sort of cloud where it might get lost in the future. Even if it is stored in vogons server, will the attachments get purged over time?
Reply 319 of 325, by collector
I was not implying you were, just making the case for preserving posts, including the images in the posts.
That is the difference between linking and uploading an image. For it attachments to be deleted, outside of something like a server hard drive crash, it would take direct action by a mod, administrator or someone with FTP access to delete them.
