Reply 20 of 21, by superfury
Just tried Zork Nemesis on MS-DOS.
Entered the following lines before running ZORKDOS (because UniPCemu has no 387 or any FPU for that matter):
set GO32=emu D:\emu387
set 387=N
Should that be enough to get it to run without a FPU emulated by the emulator itself (using emu387 instead)?
Got a exception 07 without the "set 387" line at least.
That's immediately after rendering the mouse cursor (some kind of anchor) followed by a greyish rectangle drawn around it.
It keeps crashing in the same way:
Base relative address: 0006640F
Exception(07) CS:EIP=0160:001d8415
DS=0168 ES=0168 FS=0168 GS=8aF4
EAX=00268AF4 EBX=000000A0 ECX=001D8D70 EDX=00268AF4
ESI=001C51E0 EDI=001F1874 EBP=00246C70 SS:ESP=0168:00246C04
Then it simply hangs and is unresponsive.
Edit: The 387 environment variable has no effect on it it seems?
UniPCemu Git repository
Reply 21 of 21, by superfury
Just tried Magic Carpet. Turning on Anaglyph 3D mode looks right (blue and red overlay in the right locations, running in RGB565 16-bit color mode), but don't have anaglyph (red/cyan) glasses to verify.
It's third (3D) display mode is probably fine too, but can't verify it's results either. That one is back in 256 color mode.
