Unboxing and part 1 of my Monotech PC NuXT build.
Unfortunately after like 6 render attempts I finally got it to work but there is a short section from about 3:53 to 4:31 where the video blanks out several times. You can skip it or tough through it. It was 3 hours of troubleshooting then 3+ hours of rendering and another like 12 hours of processing on YouTube. I'm just going to have to leave it that way. I put a warning in the video description as well but I'm sure I'll get comments on it. 😁 This happened because the video editing software I use doesn't seem to like the video files off the Osmo Pocket I used. I loaned my normal 4K Camera to a friend this weekend, but will have it back on Monday and I'll start on part 2.
Aaaaaaaaanyway, I hope you enjoy it. As always I do all my videos with very little prep work, so you see most of the same issues I might run into. Hope you enjoy it.
https://www.youtube.com/watch?v=7_C0sEBgl3s
Full disclosure I also posted this over on the NuXT thread. NuXT - micro-ATX IBM XT (LGR review)
YouTube channel
https://www.youtube.com/channel/UCTfnRX4AWhbYJuguUcEff-g
Main Systems
NuXT
IBM 5140
486 DX4 100Mhz (Mainly DOS)
AMD K6-2 500Mhz (Mainly DOS)
AMD Athlon 700Mhz 9700 Pro (Win 98)
Pentium D 3Ghz 4670 AGP 8x (Win XP)
