I remember this as a kid "Cant delete files in dos - no room"
Announcements, advice, random banter, unrelated discussion, et cetera.
Postby GabrielKnight123 » 2019-11-21 @ 17:18
At my friends house I was told we cant use the pc because there was a problem but even to this day I have never seen this error again because somehow his dad either completely filled the hard drive or something else in Dos was stopping files from being deleted. An error message would come up about no room on the hard drive to delete files but I cant remember if programs ran because of strict instructions not to mess with it till the techie fixed it. So is it possible to fill a 2GB partition, I presume this was his setup for C:\, to the brim so that deleting is disabled?
PS: lets assume there was only one partition and it was a 486 of some sort I do remember the pc case it was the extra tall type that went to the moon with reinforced plastic feet like a moat around a castle to stop it from tipping over but it looked great and only had one cd rom drive and a million leftover 5 1/4 drive bays I found one similar in height a while ago that I'm restoring but it has a slide panel to hide the drive bays when they're not in use, I'll post some pics soon in Milliways as the front had stickers on it and I dont know if I could of done better than the buffer I had to bring it back to a new looking shine.
GabrielKnight123
Re: I remember this as a kid "Cant delete files in dos - no room"
Postby bestemor » 2019-11-22 @ 20:21
Well, I have actually had this exact problem recently, on a Win98 machine ! (Pentium4)
On which there were some errors(?) in the file/storage information, over-reporting how much free space there really was, so that my almost full disk was actually FULL before I knew it.
Now, these errors happen on a regular basis with win98 it seems, but I've always managed to scan the disk before it got too bad. Not this time though.
Granted, that day I was living with just a 34-40mb free on a 80gb disk (!), due to heavy internet use(man, those temp files etc), and was just about to go delete some stuff, when everything totally locked up due to zero _actual_ space left!!
As the garbage bin need some space for where to put what you delete, apparantly... even when you change the settings to instant delete. (or am I mistaken?)
Had to remove the whole physical disk and connect it to a different computer, so I could finally delete something via that one.... :\
So, I'm now making sure to both do disc scans more often - to correct the file tables or whatever, and not filling it up as much as before... LOL :P
User avatar
bestemor
Postby cyclone3d » 2019-11-22 @ 21:11
Make sure to set your temp internet files space to 250MB or lower in Windows.
Some of the earlier versions of Windows (up till at least XP) would default to some ungodly amount that didn't even make any sense.
User avatar
cyclone3d
Postby DracoNihil » 2019-11-22 @ 22:11
Is there a way to just, not have Temporary Internet Files at all? I know in Firefox via about:config you can set it to the point there's absolutely no disk cache permitted. It can either be set to remain resident in RAM instead or just not have a cache whatsoever.
It also wouldn't surprise me considering how hap-hazard FAT is as a filesystem that this kind of thing eventually happens. Though I thought MS-DOS had no concept of a "Recycle Bin" and all that "UNDELETE" did was try to find parts of the filesystem that were marked "deleted" and attempt to recover it if it wasn't already overwritten by further operations.
User avatar
DracoNihil
Postby jmarsh » 2019-11-23 @ 01:35
The only way I could think of this happening is if you were using a strange version of DOS that always wrote directory changes to new clusters and then freed the old ones, instead of just overwriting them.
jmarsh
Postby Shagittarius » 2019-11-23 @ 03:51
Kinda sounds like the kinda thing doublespace might say.
User avatar
Shagittarius
Postby brostenen » 2019-11-23 @ 18:01
Shagittarius wrote:Kinda sounds like the kinda thing doublespace might say.
My thoughts as well.
Jah ich will trynen... Die Leute wie macht scheisse in dem Grünen.
User avatar
brostenen
Return to Milliways
Who is online
Users browsing this forum: pote2639, Xupack and 2 guests
