First post, by simbin
Want to tidy up my loose ATX motherboards and other PC cards.
Recommend anything relatively inexpensive, that's pretty decent and stackable?
WIP: 486DX2/66, 16MB FastPage RAM, TsengLabs ET4000 VLB
Check out my Retro-Ghetto build (2016 Update) 😀
Commodore 128D, iBook G3 "Clamshell"
3DO M2, Genesis, Saturn, Dreamcast, NES, SNES, N64, GBC
Reply 1 of 6, by kixs
I use Ikea plastic containers. Bigger for motherboards and larger VLB/ISA cards. And smaller for ordinary size ISA/PCI cards. Sometimes I put the cards/motherboards in antistatic bags and sometimes I just put some newspaper sheet in between them when stacking. The usual cardboard boxes in proper dimensions are also fine. You can also use motherboard boxes, I usually put two motherboards inside.
Reply 2 of 6, by simbin
kixs wrote on 2020-10-17, 20:34:
Which containers specifically, and can I order them online? - no Ikea store in my area, thanks
Reply 3 of 6, by kixs
For motherboards and larger cards:
https://www.ikea.com/gb/en/p/samla-box-with-l … rent-s39885645/
Standard VGA cards:
https://www.ikea.com/gb/en/p/samla-box-transparent-70102972/
Reply 4 of 6, by wiretap
I use these. Slightly over $1ea. I put a piece of foam in the bottom and have the motherboards in an ESD bag. 1 board per box, labeled accordingly.
https://www.amazon.com/dp/B00BT3EQNE/ref=cm_s … i_dbfJFb4ESSW4E
My Github
Circuit Board Repair Manuals
Reply 5 of 6, by simbin
I found these, and they're the perfect size. With my leftover Prime Day promo credit, they were just about $20. 🤞
https://www.amazon.com/gp/product/B01H2NWDXY
