First post, by Malik
Greetings.
Does anyone know of a simple command line utility to run in DOS to show if the system is running in Real mode or Protected mode?
Just a curiosity. Thanks.
Reply 1 of 6, by Falcosoft
Malik wrote on 2021-10-12, 09:45:
Greetings.
I have compiled a simple utility that just shows that:
PMODE.zip
589 Bytes
13 downloads
Website, Facebook, Youtube
Falcosoft Midi Player + Munt VSTi + BassMidi VSTi topic
Reply 3 of 6, by retardware
@Falcosoft
Very nice small utility 😀
Question:
Is it possible to also show if unreal mode is active?
For example, there are games that do not work in v86 mode, only in real mode.
For these, I like the Micronics MICEMM memory manager, as it is an EMM386 equivalent that can work in unreal mode (eg with the REAL option), so EMS and UMBs are available without v86 mode.
Reply 4 of 6, by Falcosoft
retardware wrote on 2021-10-12, 16:13:
@Falcosoft Very nice small utility :) […]
@Falcosoft
Question:
I do not know how to check unreal mode easily (since unreal mode isn't an actual CPU mode) and I also do not know if it's relevant in this context: i.e. unreal mode has the same characteristics as real mode (you can run privileged instructions etc. the same way as in real mode).
BTW here is a modified version that sets the exit code according to real/protected mode result (0/1) so you can use it more easily from batch files by testing 'errorlevel'.
PMODE.zip
749 Bytes
10 downloads
@Edit:
It does not check if CPU is supported or not but works correctly on any 286+ CPU (386 is not required)
Reply 5 of 6, by Gmlb256
How EMS memory performs with that expanded memory manager? Seems interesting considering that it uses the uncommon unreal mode.
Falcosoft wrote on 2021-10-12, 17:06:
I do not know how to check unreal mode easily and I also do not know if it's relevant in this context: i.e. unreal mode has the […]
I do not know how to check unreal mode easily and I also do not know if it's relevant in this context: i.e. unreal mode has the same characteristics as real mode (you can run privileged instruction etc. the same way as in real mode).
PMODE.zip
@Edit:
The ERRORLEVEL usage for batch files and the fact that it can work with 286 CPUs makes it useful. 👍
