Halo Combat Evolved
Reply 21 of 33, by dr.zeissler
Mac Versions suffer from different glitches in lightning and shaders too. Radeon 2600 seems to be fine, rest has several different glitches.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 22 of 33, by Dege
Vaporeon wrote on 2020-05-27, 16:38:
Hey, was anything found on the above plasma glow issue?
Was this issue fixed only partially? I thought it's working with the 2.63.1, I mentioned it in the changelog (Fixing a minor D3D DXBC generator bug (Halo CE)).
Reply 26 of 33, by dr.zeissler
Are the shaders "universal"? So can I copy them from the PC to the Mac-Version?
I did some additional testing for the MacVersion:
Core2Duo MacMini Nvidia9400m shared gfx. Mac OS 10.6.8 with Halo Mac Universal DVD-Version 2.0
- Vsync is broken. Activating Vsync leads to strange fps and hickups. 30fps setting is working OK.
- Shaders are set to vertex+pixelshaders (advanced shaders produces flickering on some textures)
- Lightning, shadows seem to be ok. for the reflections and the bumps I am note sure.
If I update this universal (ppc+intel) version to the next version 2.0.2 I get broken shaders and broken lightning.
Vsync is fixed though but now the game is ugly. If I only interchange the binary it's also broken...hmm strange...
How are the floor-textures in "Two Betrayals" supposed to look like...are they shiny glass or are they blue metallic?
thx!
Reply 27 of 33, by Dege
Vaporeon wrote on 2020-05-30, 19:25:
Load the MP map "damnation" and there is a plasma rifle on the ground (weapon in that image) in a room that is directly next to the waterfall.
Thanks! (though I used cheat_all_weapons instead, proved to be more simple)
So, I debugged how the plasma riffle is drawn and turned out that the glowing plasma-power is always rendered but with varying transparency factor.
For example, it's clearly visible when it's lying on the ground. Or, when I hold it in my hands and make a shoot then it fades away gradually.
It's not clear for me exactly how, but the results of some occlusion queries also affects the value of the transparency factor. The more visible pixels the more opacity.
The thing is, when resolution is forced (to be larger) through dgVoodoo then occlusion queries report more visible pixels than expected, that's why the glow isn't (almost) fully transparent.
I tried the game with unforced resolution/MSAA and it worked as expected in that case:
The solution would be scaling the result of occlusion queries according to the resolution. I'll consider it for the 2.7.x series (but not for 2.6.x).
dr.zeissler wrote on 2020-05-31, 08:14:
I don't think that. Probably the sources that they are generated/compiled from have common roots.
But PC version works with DX bytecode shaders that aren't compatible with OGL glsl-shaders the Mac version need (I don't know the Mac version at all though, I just guess it's OGL).
Reply 28 of 33, by dr.zeissler
Hi there, I managed to get Halo on Mac working with HD3000 by using HaloMD and copy the campain from Halo to HaloMD.
HaloMD seems to have fixed most of the issues. But Bumps are still wrong...
btw. shaders used in riddick are "universal". it worked copying that patch to my mac installation: https://www.moddb.com/mods/the-chronicles-of- … nhdr-shader-mod
Reply 30 of 33, by MrEWhite
Delfino Furioso wrote on 2020-06-19, 09:25:
I have a question, just out of naivety.. Why should we use dgVoodoo with HaloCE when Chimera exists?
Well, they both achieve two different things. Using dgVoodoo for Halo allows you to enable proper hardware anti-aliasing, along with fixing shaders on PC without any workarounds. Chimera just adds fixes and QOL changes to Halo.
Reply 31 of 33, by Chachamara
Total noob here. I'm using Chimera, which disables Halo's in-game gamma adjustment setting, and specifically recommends dgVoodoo2 as a workaround. So I really only installed it to boost the brightness a bit.
Anyway, I'm encountering an issue where certain elements (textures?) appear completely white, or in one case, black and white.
Example screenshots taken with default settings:
White gunfire
White video settings menu background
Black and white "Connecting to server" background (I'm using Universal UI version 1.1)
I'm using dgVoodoo2 version 2.71.2, but I've also tried version 2.6 (earliest the working version I found) which had the same effect. Tweaking various settings didn't seem to help.
I'm playing Halo Custom Edition with the 1.0.10 patch. OS is Windows 10 version 1909. GPU is a Radeon RX Vega 64. If anyone could offer suggestions, it would be much appreciated. Thanks in advance!
Reply 33 of 33, by Chachamara
ZellSF wrote on 2020-10-24, 21:26:
You need to set Output API to Direct3D 12.
While that fixed the issue I described, it also seems to disable the brightness adjustment, which unfortunately defeats the purpose of installing it in the first place. The brightness looks identical even when it's set to 0% or 400%.
Edit: Checking "Inherit Color Profile in full screen mode" seems to fix the brightness issue with DIrect3D 12. Thank you very much for the help!
