First post, by dccs
So when I start the game with dgVoodoo, a splash screen shows up at a low resolution (bypassing dgVoodoo for some reason) and then the game just closes. Natively with DX8, works just fine without any crashes, albeit at a very low framerate during gameplay on Windows 10 (sometimes even below 10 fps). I wonder if this can be patched in dgVoodoo or not.
Reply 1 of 5, by ZellSF
Well for starters it's a DX9 game, not a DX8 game:
https://www.mobygames.com/game/windows/terror … kedown/techinfo
So if you're copying D3D8.dll, it shouldn't do anything at all (no clue why it crashes), you need to copy D3D9.dll. Which works fine here.
Edit: it crashes because of ddraw.dll , remove it as it is not needed.
Reply 4 of 5, by dccs
Yes, I deleted all dgVoodoo files, and put D3D9.dll, dgVoodoo.cpl and a new dgVoodoo.conf as well, it still doesn't work. I tried all possible configs in DirectX tab in the dgVoodoo control panel, and nothing works. Check it out:
