First post, by WhiteBear
C&C Generals currently suffers from a double mouse pointer issue that happens when scaling modes are used or when forcing the resolution. I am using the Origin version of the game with all dgVoodoo settings kept to default except for using Stretched, keep aspect ratio scaling mode.
Reply 2 of 3, by WhiteBear
Dege wrote on 2022-08-10, 13:04:
Try enabling option GeneralExt\EnableGDIHooking, it also hooks the cursor handling so double and flashing cursor should be gone.
I will try that and report back the results. Thanks for the help.
Reply 3 of 3, by WhiteBear
Thanks a lot Dege. I have just tried that option, and the game finally works fine with dgVoodoo. No more double mouse pointer. I can finally run the game in 4:3 without having to suffer with zoomed in field of view due to 16:9 or 16:10 aspect ratios. I can also enable MSAA for better image. dgVoodoo is literally the best thing that happened in the history of gaming. I have lots of old games that don't run well unless dgVoodoo is used. Thanks again Dege.
