Disable A: and B: drive letters in MS-DOS
Getting old software/games running on older hardware.
Postby Doppler » 2018-2-14 @ 06:59
Is it possible to disable or hide A: and B: drive letters in MS-DOS so that they couldnt be accessed and seen in file managers like norton/volkov commander?
I know it's just a visual preference, but still I dont use any diskette drives in my computer so I would be happy to disable these letters :)
Doppler
Re: Disable A: and B: drive letters in MS-DOS
Postby Kamerat » 2018-2-14 @ 09:29
You can use Drive Letter Manipulator for that purpose.
User avatar
Kamerat
Postby derSammler » 2018-2-14 @ 09:56
Unless a program is badly coded, you should not see A: and/or B: when setting them to "none" in the BIOS.
derSammler
Postby Doppler » 2018-2-14 @ 11:35
Kamerat wrote:You can use Drive Letter Manipulator for that purpose.
Thanks! it works! :D
Doppler
Postby Cyberdyne » 2018-2-14 @ 11:44
Sometimes, even DOS is badly coded, and even BIOS is badly coded, and those A and B drive are hard to die form your list.
I am aroused about any X86 stuff that has full functional ISA stuff. I think i have problem.
User avatar
Cyberdyne
Postby Kamerat » 2018-2-14 @ 18:33
Doppler wrote:Thanks! it works! :D
Nice! :D Used it myself to remove ghost floppy drives from Windows 98SE, just ran it from autoexec.bat before Windows booted.
User avatar
Kamerat
Postby Doppler » 2018-2-16 @ 07:41
Reporting back with more tests.
Unfortunately it works only under volkov commander. In Dos Navigator and others similar file managers, the A letter is still visible, no matter what. Look like I'll have to live with it :) But anyway, thanks one more time!
Doppler
Return to Software
Who is online
Users browsing this forum: infania and 6 guests
