First post, by Jade Falcon
Rank BANNED
BANNED
So I want to setup a few boxes on my server that can be remotely logged into from a retro system.
Dose OS/2 or win3.x have support or a app that can be used to log into to a system via RDP?
Basicity I need a RDP client app for win3.x or os/2
Thanks.
EDIT:
I'm going to guess the windows NT 3.x or win3.1 for Workgroups might have something that would work.
Reply 1 of 14, by DosFreak
You can RDP from 9x (Not sure if this works with (10/2012)
OS/2 you can use a VNC client
3.1 I don't think there is a VNC client but I could be wrong.
Make your games work offline
Reply 2 of 14, by Jade Falcon
Rank BANNED
BANNED
Yeah I thought 9x had RDP. I'm not sure is Vbox supports VNC, if it does I cold use it. I thought NT 3x or 3.1 workgroups had something.
Basicity I'm going to setup a few boxes on a server and use the retro PC as a client when I need I need to run a newer app or something. That and it would be a cool setup.
Reply 4 of 14, by DosFreak
NT4 Terminal Server comes with Terminal Services (predecessor to RDP). It worked well.
If you have the old Citrix software you can use Citrix Winview on 3.x and OS/2.
According to the following RealVNC works on NT 3.51 if you want to run the VNC server or client in the guest:
https://archive.realvnc.com/pipermail/vnc-lis … ber/035641.html
Not sure how compatible VirtualBox VNC would be with these old clients. Only one way to find out.
Reply 6 of 14, by Jade Falcon
Rank BANNED
BANNED
Indeed. I could always use something other then Vbox or a older version of Vbox. Not like the system will be used for anything important or outside of a lan.
Jorpho wrote:
It seems DESQview/X will let you run Win3.x applications remotely.
http://toastytech.com/guis/dvx3.html
Neat, but not really what I'm looking for. I want to login to a another system from a windows 3x or os/2 system.
Basically I'll be using a old system and logging into a VM on a newer system. Kind of like a terminal server setup.
Reply 7 of 14, by chinny22
If you have Win2k server installed, TSclient DosFreak mentions above can be found in
\%systemroot%\system32\clients\tsclient
It's also handy as newer version of RDP dropped support for NT4 Terminal server and this way you can have both on the same WinXP box
Reply 8 of 14, by Ampera
Remote terminals have been around, probably as long as computers have been. Even DOS has support for different Telecom and RS-232 terminals/networks allowing you to pop in. More advanced systems like server have baseboard controllers, that with special software can power on, power off, input and receive data over something like a modem or null modem connection.
I don't know of exact examples, but I know they exist. You don't have to aim for Windows, remote terminals have existed forever.
Reply 9 of 14, by Jade Falcon
Rank BANNED
BANNED
True I don't need to use RDP/VNC or windows, But I would like to stick with RDP or VNC. And I would like to only have Dos and win3x or os/2 on the retro system.
Reply 10 of 14, by jade_angel
It should be possible to build the mostly-Unix RDP client "rdesktop" under OS/2, against SDL. I can't say I've tried it, but apparently it's doable.
Also, you can probably run a VNC server on the machine that's running VirtualBox, and use a VNC client on OS/2 (probably cleaner than Win3.1). That seems like a lot of fungus, though. I'm somewhat baffled that VirtualBox doesn't support VNC natively.
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
Reply 11 of 14, by mrau
vnc is the fastest solution, sometimes it requires a driver to get the data fast/with low cpu usage but then it just easily works on a 100mbit line without compression; the lan card better be somewhat efficient;
Reply 12 of 14, by RJDog
This site I have found to be immensely useful in finding network drivers for DOS... NetWare, Packet Drivers, TCP/IP...
http://www.veder.com/nwdsk/
But most interesting to this conversation, there is an RDP client for DOS! I have not personally tried it, but I assume it works...
Reply 13 of 14, by Jo22
PC Tools 7.x also had some sort of a remote desktop, I think.
Windows 3.0 could perhaps be supported in real/standard mode there (not tested).
Reply 14 of 14, by ynari
I've never tried rdp from OS/2 - check hobbes, maybe there's a client. Failing that you could run XFree86 under OS/2 and compile rdesktop for that..
It's even possible that Odin32 is functional enough to run a Windows RDP client (but probably not, bet it fails trying to call authentication APIs)
