How about a MR-BIOS ROM file repository?
Reply 40 of 169, by Auzner
Thanks for the advice everyone. I will try dumping it again tonight as if it were a 28-pin 27c256:
166.08 KiB
All these variants of the 28-pin!
84.49 KiB
Reply 41 of 169, by keropi
^ better try as 27C512 and see if you get duplicate data (2x32kb data)
🎵Link to buy a PCMIDI mpu
🎧Orpheus soundcard project
💻WTB Amstrad PC7486SLC-33 system
Reply 42 of 169, by Anonymous Coward
In my experience, almost all 386 BIOSes that use a single chip are the 512kbit variety.
Reply 43 of 169, by feipoa
And 256kbit was largely for VGA ROM's?
Reply 44 of 169, by Anonymous Coward
yup
Reply 45 of 169, by appiah4
Just dropping these two MR BIOS manuals here, I harvested them from the eSolutions web site; still poking and trying to find a way to get to the BIOS files 😎
I have a board from 1991 with the MR BIOS on it, would anyone wager a guess as to what the HDD size limitation would be? I'll get a CF card of the according size. I'm thinking of playing it safe and going with 512MB which should be plenty enough for a DX2-66.. But if I can get away with 1 or 2GB, why not?
    mrb33x.zip
    1.8 MiB
    58 downloads
    mrb166.zip
    75.28 KiB
    56 downloads
Reply 47 of 169, by feipoa
512 MB ok for your DX2-66 system? I need at least 2 GB. I use SCSI so the onboard BIOS limit is unimportant.
Reply 48 of 169, by Anonymous Coward
appiah4 wrote:
I am going to build a system with this board sometime in the near future, I will try to dump the bios with uniflash.. […]
For now, please see attached the copies I found of the latest and large HDD patched Mr BIOS bioses.
This board is supposedly based on Headland HT 340 "SHASTA" or possibly Opti 82C802G . Can you confirm which?
Reply 49 of 169, by keropi
and why use uniflash for this? if the board runs then NSSI is better to make a BIOS dump
Reply 50 of 169, by feipoa
Do you know what the benefits of NSSI copying a BIOS is compared to Uniflash?
Reply 51 of 169, by keropi
not having to remove the IC and inserting it to a NIC to do the job?
Reply 52 of 169, by feipoa
Doesn't uniflash work with most PC BIOSes in the computer?
Reply 53 of 169, by appiah4
It has the Headland chipset.
Reply 54 of 169, by Anonymous Coward
Were there other 486 boards that used the HT340 chipset? Do they work with EDRAM as well?
Reply 55 of 169, by appiah4
This I do not know I only have experience with this one board.
Reply 56 of 169, by Auzner
Here's the correct binary for the Forex 300 MR BIOS as a 27C512 (64kB as opposed to the 16kB)
45.83 KiB
Just recently I got several other motherboards so I ordered a USB programmer.
Motherboard photo:
download/file.php?id=42321&mode=view
    forex300.zip
    41.84 KiB
    55 downloads
Reply 57 of 169, by keropi
thanks for the update Auzner - I'll fix my post with the new dump 😀
Reply 58 of 169, by Anonymous Coward
I think I finally tracked down the BIOS image for Macronix 305/306. It's for the Octek Jaguar V. It came from a Russian Hardware Museum site.
http://hwmuseum.pp.ua/index.php?route=hardware&dev=3
I think this image is actually floating around as an attachment on vogons somewhere, but it hasn't been added yet.
Reply 59 of 169, by keropi
thanks Anonymous Coward , added the BIOS image in the 2nd post list
