First post, by warstorck
Hi all I'm having a really weird problem trying to play Daggerfall on my MMX 233 Machine. For some reason the mouse sensitivity is super high and when you go into the options menu the bars for the sensitivity extend all the way outside the screen. If I lower them they simply revert back as soon as I close the options menu. I've tried several different installs of the game including the unpatched version from Bethesdas website without any addons, Daggerfallsetup, copying my GOG install and so on. I've also tried different CPU clock speeds and two different mice.
Anyone have any ideas what might be causing this?
Reply 1 of 2, by realnc
Did you save the game after changing the setting? Daggerfall saves many of its settings in the save games, not in the settings file. Maybe mouse sensitivity is one of those.
(That also means that restoring an older save will revert those settings.)
