First post, by Chadti99
Having an issue in GLQuake 1.09 where the HUD flickers. Noticed in the 3dfx MiniGl 1.47 readme file it mentions to enable triple buffering to eliminate the issue and to use console command “gl_triplebuffer 1”. Problem is, my version of quake doesn’t seem to recognize “gl_triplebuffer” as a valid command.
Any ideas? Thanks for reading!
Reply 1 of 4, by gaffa2002
In the console, try typing:
gl_ztrick 0
You will probably need to add it to autoexec.cfg to avoid having to execute it every time you run the game.
LO-RES, HI-FUN
My DOS/ Win98 PC specs
EP-7KXA Motherboard
Athlon Thunderbird 750mhz
256Mb PC100 RAM
Geforce 4 MX440 64MB AGP (128 bit)
Sound Blaster AWE 64 CT4500 (ISA)
32GB HDD
Reply 2 of 4, by Chadti99
gaffa2002 wrote on 2021-04-04, 15:11:
gl_ztrick 0
Apologies for the late reply, just tried it and unfortunately still seeing the same issue, thank you for your suggestion.
Reply 3 of 4, by Gamecollector
Try SET FX_GLIDE_ALLOC_COLOR=3 (or check "Force triple color buffering for glide apps" in the V2 panel).
