First post, by Pajeroking
- Newbie
Hi people,
I have installed Unisound tool in order to have sound in games in MS dos mode.
My problem is that I am not able to edit the autoexec so it can run on computer startup, i need to run it manually every time.
Sound card : Genius k0237014 based on Crystal CS4237 chip.
The file path is C:\kituri\unisound.com
How should the sound card initialization look like?My autoexec looks like:
SET BLASTER =A220 I5 D1 T4 J200 P330
C:\kituri\unisound.com /v80
I also tried with
SET ULTRASND=240,3,3,11,11
Adding only the second line (location of unisound exe) does not work either
How exactly should i know what to add in the first line?
Thanks !
