First post, by aspiringnobody
Is there a way to prevent the DHCP BSOD that happens on first launch of WfW 3.11? I'd like to be able to have the ethernet cable unplugged from this PC when I'm not planning on using the network, but still have windows boot in a reasonable time. Is there some config file I can disable the DHCP check on startup in? I'd rather have change a cfg from dos every once in a while than sit through the timeout every time if that's an option.
Thanks in advance.
Reply 1 of 5, by aspiringnobody
aspiringnobody wrote on 2021-12-02, 23:18:
Thanks in advance.
I figured it out. Go into Main -> Windows Setup -> Options -> Change Network Settings -> Uncheck DHCP and enter an IP/Subnet
Leaving this here for future searches.
- AN
Reply 2 of 5, by BitWrangler
Good man for posting your workaround.
Though I am really puzzled why I haven't had this problem in the past, because I have had wfwg networked... I think maybe because I had older winsocks that I had to manually launch to enable TPC/IP.
edit: or they launched when I used a TCP/IP application, I think Microsoft Networking was bound to IPX/SPX rather than TCP/IP
Reply 3 of 5, by Caluser2000
BitWrangler wrote on 2021-12-03, 05:06:
Wasn't it NetBUE? NT initially used BSDs tcp/ip stack.
Reply 4 of 5, by weedeewee
Caluser2000 wrote on 2021-12-03, 17:43:
netbeui 😁
Do not ask Why !
Reply 5 of 5, by Caluser2000
weedeewee wrote on 2021-12-03, 21:12:
netbeui 😁
Thank you kind sir.
