First post, by Jackhead
i tryed to get tomb Raider 1 working with my voodoo 5500. I read that later voodoo cards use the rushPatch.
Well it works but only with resolution 640x480.
So how i get the "MegaMonster" voodoo 2 sli Resolution 1024x768 working with a voodoo 5500?
I use windows98SE, and the Directors Cut Edition with the Rush patch.
Anyone?
regards
Chris
Reply 1 of 21, by Meatball
This works only for Tomb Raider 2 and 3 by disabling the Z-buffer. Tomb Raider 1 is hard coded into 640x480 with 3dfx. Other options for the original Tomb Raider for 1024x768 include:
Power VR (practically unplayable at this resolution, DOS/Win9X)
Glidos (also works for GOG and Steam)
OpenLara (many different kinds of hardware)
Tomb Raider Automated Fix 1.2.1 (for GOG and Steam)
***->WINNER, 1ST PLACE<-***
2022 #QUAKE3totheMAX -560.5fps-
Brain Drain Retro LAN https://discord.com/channels/799008837918261328
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
DDR@411MHz (2-3-3-3)
GeForce 256 DDR@144/344MHz
ESS Maestr0-1
Reply 3 of 21, by Meatball
Unfortunately, there's no Tomb Raider exclusive to the Voodoo2. There's one for the Voodoo Rush and the other for the Voodoo1. However, if you're not playing on either hardware, you'll also be missing some special effects like shadows on the original Tomb Raider. For Unfinished business, I believe the Rush patch still has the shadows, though, when played on newer 3dfx hardware.
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
ESS Maestr0-1
Reply 4 of 21, by Gmlb256
Meatball wrote on 2022-05-09, 18:45:
At least the original Voodoo Graphics executable works with Voodoo2 cards after setting some environment variables which can be found on the V2-AUTO.INF file.
Reply 5 of 21, by NostalgicAslinger
Meatball wrote on 2022-05-09, 18:04:
Not really, TR1 runs good on a PowerVR PCX2 in 1024x768 resolution. Played through to the last level.
Here is a capture from me: https://streamable.com/6nmxfd
Reply 6 of 21, by Meatball
NostalgicAslinger wrote on 2022-05-11, 17:25:
It does look good. I must have had it running in a lousy configuration.
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
ESS Maestr0-1
Reply 7 of 21, by Jackhead
What cpu/gpu you use with the PCX2? Looks really good 👍🏻 And can i use a pcx2 with dos 6.22 or do i need a win for setup?
Reply 8 of 21, by NostalgicAslinger
I use a Celeron 333@375 (75 MHz FSB) Mendocino Slot 1,FIC VL-601 i440LX, 256 MB SDRAM, S3 Savage4 32 MB AGP and a single Voodoo2 12 MB.
I have started under Windows 98 SE, never tested under DOS...
Reply 9 of 21, by Jackhead
Thanks for the info, i run a elsa riva tnt2 agp with a amd k3+ @600MHz . Maybe give it a try when i found one for a ok price.. Looks like there no dos driver, so maybe i dont need one like a voodoo1/2 under dos.
What was the latest power vr exe for Tomb Raider? V2. 1.0?
Reply 10 of 21, by dr.zeissler
RAVE-Version has native 1024x768 support.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 11 of 21, by TrashPanda
Is the V5500 able to run Glide 1x and 2x games ? I always assumed that the newer Voodoo GPUs had issues with the older Glide API versions.
Oh noes, the cap let the shmooo out 😁
Reply 12 of 21, by Jackhead
dr.zeissler wrote on 2022-05-12, 09:50:
RAVE ???
TrashPanda wrote on 2022-05-12, 10:09:
pretty good support, with patches and tweeks. Sometimes you just use another dll or you have a patch.
Reply 13 of 21, by rasz_pl
another video showing 20-30 fps https://www.youtube.com/watch?v=5GMesT4WKzI
Reply 14 of 21, by Jackhead
i bought now a pcx2 board. Will see how it perform and scale with my setup. I will also have some different GPUs to test it. I also see that 800x600 it can go up to 60fps what is really interesting.
Reply 15 of 21, by Jackhead
I got today the Matrox 757-00 PCX2. First at all that chip got really hot..
So i decide to give the old board some cooling. What was a good choice i think, it runs now much cooler around 35°C.
Tests with the Riva TNT2 show its not compatible with the pcx2. Than i tryed an old Trio64 S3 2MB GPU and it works fine.
But with the S3 cant switch to 1024x768.. 800x600 is the max.
I also tested WIn98SE and pure DOS 6.22. Both work without problems. So running the board in dos setup is no problem.
I will try a rage 128 pro and some other cards next days.
1.46 MiB
618.49 KiB
With S3 Trio64 2MB GPU=
1.15 MiB
Reply 16 of 21, by chuky
You need to run this: Tombpcx2 uvbe
I'm not sure if you also need to press F8 as well. You can also set higher refresh rates, for example if you run "Uvconfig -e120" and then "Tombpcx2 uvbe" it will run in 120 Hz in some resolutions.
Reply 17 of 21, by Jackhead
Thanks for the tip. But it was the 2MB RAM that the Trio64 cant run 1024x768. For testing i installed a V5500 and i can switch to 1024..
Runs pretty good, sometime the frames go down to 20fps but overall they over 30fps. On 800x600 its on 35-45fps what is pretty nice to play.
I will test a SIS 6326 and a Matrox G250 soon, because the voodoo musst be back in my win98 setup.
Reply 18 of 21, by Jackhead
Tomb Raider PCX2 DOS6.22:
(AGP)
ATI Rage 128 Pro = Works really great with the PCX2 board, 1024x768 possible with around 21-35fps, 800x600 solid 35-45fps
V5500 = Works ok with the PCX2, 1024x768 possible around 19-31fps
Matrox G250A = Works only 800x600 with the PCX2
Matrox G450 =
Diamond Speedstar SIS 6326 =
Reply 19 of 21, by Jackhead
Matrox pcx2 + Matrox G400 max + K6III+ 600MHz 1024x768 solid 30fps and awesome vga output:
1.59 MiB
