Reply 80 of 578, by keropi
got another friend interested so I am up for 2x kits + brackets (gotta have brackets 🤣) without SIDs
cT89QGt.gif Amstrad PC7486SLC-33 wanted , click me for AmiBay ad!
Reply 82 of 578, by Fagear
Finally, I have CD74HC192 in my hands.
It works differently than K555IE6. 😐
Currently with 555IE6 jumper selects frequency between 0.89 and 1.02 MHz, but with 74HC192 installed it transforms into 1.02/1.19 MHz. So when K555IE6 divides by 7 CD74HC192 divides by 6 and when K555IE6 divides by 8 CD74HC192 divides by 7.
Interesting, I also have some DV74HC192 ICs, they are made in Belarus (also former USSR part, where K555IE6 were created). But DV74HC192 performs in the same way as "original" CD74HC192 does.
So, according to international status of the replica kit, i will fix PCB layout in next revision, so it will be compatible with HC192 ICs to allow 0.89/1.02 selection, as it printed on the PCB.
Current version of the board works only with 555IE6. With HC192 it gives 1.02/1.19 MHz clocks.
And some more info: I've got message that MOS6582A works well in the replica as the 8580 does. Both run with +9V regulator installed. 😎
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 83 of 578, by shock__
Interesting ... didn't think that would happen, but hey, minor differences between russian/soviet and western chips were already common in the 80's - like the 1818VG93 (clone of WDC1793) has a 2.5mm pin pitch rather than 2.54mm. Either way, thanks for making an international version.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 84 of 578, by keropi
^ great news!
I wonder though, maybe it would be better for the board to use for all logic the globally available 74series ICs instead of the Russian equivalents? The end user could order easily a replacement in case that it's needed.
Reply 85 of 578, by Fagear
Yes, 2.5mm pitch was pretty common in USSR.
I've tested already all other ICs and there are no any other differences between 74 series and 555 series ICs used in this card. So there will be no problems with compatibility. Also, new revision will have both 74- and 555- silkscreen markings under chips:
Reply 86 of 578, by Stojke
Shouldn't it say : PCB & Layout Made in RUSSIA? 😀
Aweosme stuff btw. I cant wait for some one to write an app to play SIDs in DOS.
Reply 87 of 578, by Fagear
Look somewhere around joystick port footprint... 🤣
Yes, I'm also waiting for it. I'm also a programmer (C, C++ and many other languages) but never wrote something like DOS application or driver. So, I think that will be not me who will write a software.
Reply 88 of 578, by Fagear
I've scratched my head a little bit and came up with revision 2.3:
Repositioned jumpers, added two more resistors and changed layout of SID clock selector jumpers.
Also new silkscreen tips for SID clock and more tidy layout around 74HC192.
PCB is now universal: it can take either K555IE6 or 74HC192.
Reply 89 of 578, by carlostex
The more of us interested the cheaper these boards will be right? I'll take a fully assembled board, with bracket without SID. I'll get the SID's myself.
Reply 90 of 578, by Fagear
Ok.
That's right.
Currently I have "pre-orders" for 8 boards.
I have some problems with brackets... Can't find any reasonably priced manufacturer. Current layout is adapted for Keystone 9202 bracket, but it comes with no holes. It can be bought quite cheap. Haven't contacted Keystone yet for prices for custom brackets, but I feel that they will not even look at me if I'll order less than 1000 brackets. That's would be a huge price.
Didn't find any other places and I don't have any friends in metalworking industry.
1) If I'll try to drill holes for myself for all boards, that's will be slow and not accurate. Possible, but not great result.
2) I can ship compatible bracket with no holes, so end user will have to deal with it. If no joystick port needed and audio output will be taken from inside header - you can leave out output connectors and solid bracket will suit like a glove. Accurate, but feature-limiting and not great solution. Also you can drill holes yourself. Fully featured but possibly not accurate and hard to do solution.
3) Maybe I can retrace board for some already manufactured bracket, for example, take Creative CT4170 or any low-end ESS AudioDrive. Replace output RCA with 3,5" mini-jack, use second one for SID "Audio In" (theoretically can be useful) and leave third unused.
What do you think?
Reply 91 of 578, by shock__
Swapping the RCA jack against a 3.5mm one sounds reasonable to me - considering RCA jacks were barely used on consumer grade soundcards anyways.
Another question ... what's up with the rightmost electrolytic cap? Are those 4 additional pinholes for axial caps?
[Z?]
Reply 92 of 578, by Fagear
Got it. I'll wait for some more opinions from others, but feels like three 3.5mm are the way to go.
Fagear wrote:
I've managed to write some marketing crap for the replica. 🤣
+ Output electrolytic capacitor now can be replaced with film one
That's for those audiophiles, who hate electrolytics in audio path. Output cap can be replaced with film (polypropylene!) capacitor. 😉
I have one more question: are new silkscreen tips clear? Is everything easy to understand? I think with such silkscreen you don't need any manual with the kit. 🤣
P.S. Already tried TWO boards in one PC for some "pseudo-stereo" effect. Two boards work well together, not much stereo effect though.
Reply 93 of 578, by carlostex
What do you think?
I think it's a great idea to retrace a board for a very common and cheap card so we can use the brackets. Replacing the RCA with 3.5 mini jack makes sense if one wants to recycle brackets from other cards. Excellent idea.
Reply 94 of 578, by keropi
The 3.5mm audio out jack seems a nice idea to me as well.
Also "blank" bracket is fine by me, a hole is easy to make... I also don't think many will use the joystick port tbh , this card will most likely go along another in a system so it's not really a problem , personally on the 2 kits that I'll take I won't even solder the joyport 😈
And the pcb is clear to me, I don't think more info is needed
Reply 95 of 578, by shock__
Pretty much agree there with the manual part. Except for the inductance/coil L every value for the parts seems to be represented nicely (I'd guess that one is 100uH, right?).
I just have to admit I prefer the previous orientation for the Joystick/frequency silkscreen, having it close to the jumpers rather than pointing arrows.
[Z?]
Reply 96 of 578, by vetz
Rank Hardware Mod
Hardware Mod
That's right.
Maybe Keropi as moderator over at Amibay could see if there is any interest over there?
Reply 97 of 578, by Fagear
Well, that's experimental. I've noticed that replica picks up some noise from starting hard drive, tried to eliminate it with fer-bead, but had no luck. Maybe I'll try some more "serious". In other boards there is only jumper link.
Maybe yes, but I had to add one more jumper and there were no place for clock jumpers above HC192 anymore. I had to move them below HC192. And added two resistors for them (to use 2-pin headers instead of 3-pin). So... yeah. Had to move silkscreen somewhere else.
Reply 98 of 578, by keropi
vetz wrote:
That's right.
great idea but I think Fagear should have the honors posting that.
@Fagear:
if you are interested on posting this on AmiBay go ahead, I'll activate/approve your account/posts manually and you won't have to make a bunch of hem to bypass the forum's spam protection 😀
Reply 99 of 578, by PeterLI
Congratulations! This has been a really cool project. BTW: Vintage Computer Forum / DOSForum.de / CPU World / Classic-Computing.org / Quest Studios may also have people who could be interested. Good luck! 😀
