Reply 220 of 416, by derSammler
The SD-20 doesn't even have flash memory either, it can't store any settings. The "SD-20 Editor" is used for that.
Recently got an MT-32, SC-55 and SC-88, glad i saw this post, will open them up and check before I turn them on
Glue.. Not corrosive
Context? Or did you just posted some random words?
derSammler wrote on 2020-05-24, 08:31:Context? Or did you just posted some random words?
I suppose he meant that it has glue and it is not corroding, I don't know if I agree, my SC-155 had the battery changed and there was an acid thread that almost came off the logic board.
I assumed something like that, but it seems strange that someone with 9 posts in 9 years comes out of nothing claiming that this whole thread is moot and what we see is only glue. As if Roland (or any other company) would be so dump to put glue on a battery that firmly sits in a battery holder... It's of course leaked electrolyte from the coin cell.
cyberaxe wrote on 2020-04-07, 09:11:Recently got an MT-32, SC-55 and SC-88, glad i saw this post, will open them up and check before I turn them on
The MT-32 doesn't have an internal battery unless it has been modified. But you might want to look into replacing the caps on it at some point as there are kits available for the MT-32.
i checked my SC-88 Pro when i bought it, and the battery was leaking. Lucky there was no damage on the board..
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Jackhead wrote on 2020-06-14, 12:36:i checked my SC-88 Pro when i bought it, and the battery was leaking. Lucky there was no damage on the board..
*Gulp*. I didn't know the SC-88 Pro also has one. I'll have to check tonight.
My SC-55 did have a swollen battery but no corrosion or other damage, fortunately.
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX, PicoGUS /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Which reminds me. Gotta check my SC-55 to make sure the battery didn't leak as it's been sitting for a long time without power.
Well, my SC-88 Pro battery seems to be fine. I'd like to remove it (it doesn't have it to remember any settings anyway) but I'm not sure how to get it out?
I can move it a little when I put a flat screwdriver under (or above) the battery, but it's difficult to see what I'm doing so I don't want to use too much force. Is there any trick to it? I'd rather avoid taking out the upper board.
I didn't even try without taking out the upper board... seems hard to do without.
Yeah, I guess I'll have to take it out then. I always try to avoid any chance of damaging things, but I guess it's unavoidable here 😀
So,
1. Roland MT32 (old) does not have battery.
2. Roland Sound Canvas SC55 mark I has one, i have replaced it with new.
3. Roland Sound Canvas SC88 (not the pro), i guess it has, i will have to check it.
4. What about Roland CM64 and Yamaha MU50?
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower (x2), Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
MU50 has a battery but it's soldered AFAIK
CM64 does not have a battery
SC88 has the battery, in a holder (like most Roland gear).
Headless modules (no or minimum buttons on front) intended for use with a computer only usually lack a battery, and generally also lack persistent memory into which to save settings (patches usually are saved in the computer editor).
HandOfFate wrote on 2020-07-14, 19:12:Well, my SC-88 Pro battery seems to be fine. I'd like to remove it (it doesn't have it to remember any settings anyway) but I'm not sure how to get it out?
Push back and flip up?
Some holders have a little slide you must move before removing the battery.
A video for battery replacement on a Roland Sound Canvas SC88 pro.
- Cyrix 120
- Atari 1040 STF
Having to put a tray on your bed in order to work on stuff. He must be living in a very cramped house.
Thanks for sharing the video. This will help 😀
Is there any real reason to leave the battery installed if only using for Game Music?
Thanks
Mike
