CVX4 : high quality covox adapter
Reply 460 of 484, by Benedikt
dreamblaster wrote on 2022-02-06, 09:18:
I'm thinking of making a CVX5, any suggestions for changes/improvements compared to CVX4 ?
CVX5 would be available in larger amount, it will take a few months though
You can gladly take my Replicas of Covox Speech Thing, FTL Sound Adapter and SiliconSoft SoundJr as inspiration and e.g. put a PCB with SMD components and a low-profile audio jack in a plug case.
They were supposed to be reasonably accurate replicas, but designing something that looks like the SoundJr without the bus-powered transistor amplifier would surely be an option for a new Speech-Thing-like device. The only downside is that you have to hand-solder the edge-mounted DB25 connector.
(Btw.: You have all three of them, don't you?)
Reply 461 of 484, by digger
FreddyV wrote on 2022-02-07, 12:45:
The best would be to do a Disney sound Source like, With a bigger buffer and increased output frequency.
A nice improvement over the original DSS would indeed be the ability to adjust the FIFO buffer size and the output frequency. The original DSS had a fixed 16-byte buffer and a non-adjustable output frequency of around 7kHz. This resulted in sound effects sounding somewhat lower-pitched and slower in some games that officially supported the DSS, but didn't bother to down-sample the sound assets, which were often recorded at 11kHz. Being able to tweak the buffer size and playback frequency would help with these games, and would be a nice improvement over the original design overall.
It is also possible to do a Parallel port "Covox" with DMA Support, as the parallel port support DMA.
Aside from the required complexity for such a solution, it would limit compatibility to parallel ports that support ECP. Also, there is no existing software support for such a mode.
A compromise would be some kind of enhanced mode hat would use the IRQ line of the parallel port as a more efficient way to inform the software that the FIFO buffer is full (or empty). (As opposed to having to poll the state of one of the status pins, which Is the case with the original DSS.)
But before we blow up the scope too much: just a single device with software-switchable Covox speech Thing and Disney Sound Source compatibility would already be wonderful. With adjustable FIFO buffer size and playback frequency being low-hanging fruit w.r.t. improvements over the original standard.
Reply 462 of 484, by ViTi95
- Full DSS support (FIFO + 7KHz sampling)
- Stereo COVOX support
- Funky LEDs because why not?
https://www.youtube.com/@viti95
Reply 463 of 484, by ultramars
- a serial port, like on the FTL sound adapter:
So that for example we can connect a mouse AND an MPU-232 on the computer 😎
this would be more usefull nowadays than the pass-through parallel port of the original covox, i think...
Reply 464 of 484, by dreamblaster
ViTi95 wrote on 2022-02-08, 12:48:
- Full DSS support (FIFO + 7KHz sampling) - Stereo COVOX support - Funky LEDs because why not? […]
Hi oh
this is going way beyond simple unpowered covox
maybe i do something like that as a different project.
how about just make some more CVX4, or minor changes to it ?
does anyone use the filter settings ?
Thanks for your support !
Reply 465 of 484, by digger
dreamblaster wrote on 2022-04-03, 11:58:
Hi oh this is going way beyond simple unpowered covox maybe i do something like that as a different project. how about just make […]
Hi oh
Stereo-on-One compatibility, perhaps? That shouldn't be too hard to implement. The README of the Crystal Dream demo has a schematic for it:
You can now play Stereo on a D/A converter in the parallell port. This
requires an improved D/A converter with a REAL D/A, it won't work with
resistors.
here is a drawing.
You can find the components in for example ELFA. It should work
(it does for me), but don't blame me if you burn your parallell port...
Mr. H
+ 9-12 V
To │ │
parallell │ 3.3kΩ To amplifier:
port: ┌────┴───────┐ │
│ + RefA├──┼── 22kΩ ── - ≈ 0.1µF
1 ───────┤A/B RefB├──┘┌──────────────────────┤├────── Left ch.
│ │ │ ┌────┐<-- ¼ LM324
LSB 2 ───────┤DB0 RfbA├───┴─┤Out ├──── -
: │: OutA├─────┤-IN │ +
: │: │ │+IN ├──┤
: │: Agnd├───┐ └─┬──┘10kΩ
MSB 9 ───────┤DB7 OutB├──┐└───┤ │
│ RfbB├┐ │ ├─────┴─ 10kΩ ─┬ -
PM7528HP -->│ ││ │ ┌─┴──┐ │
│DGnd CS WR ││ │ │+IN ├───────────┴─────────── Gnd
└─┬───┬──┬───┘│ └──┤-IN ├──── +
25 ─────────┴─┬─┴──┘ └─┬──┤Out │
│ │ └────┘<-- ¼ LM324
│ │ ≈ 0.1µF
- └───────────────────────┤├────── Right ch.
The pins in the parallell port is used as follows:
1 - Selects left or right channel
2 to 9 - 8 data bits (2 = Least Significant Bit , 9 = Most ...)
14 - Pin 1 inverted (isn't used in my D/A, but may be useful)
25 - Ground
See also this thread by matze79, about a prototype he made based on this design.
Reply 466 of 484, by dreamblaster
it sounds and works well as it is... so in the end,
I made a new batch of CVX4, Vogons Tuning Edition...
Available now again at https://www.serdashop.com/CVX4
    39.67 KiB
Reply 467 of 484, by dreamblaster
Made a new video showing Lunatic demo (from 1993, Extreme) played on CVX4 : https://youtu.be/HNt5Tlx6sAY
Reply 468 of 484, by dreamblaster
the new black/blue printed enclosures arrived
also I bumped into this video : MP3 playback under dos, using CVX4 : https://youtu.be/d46nYXDt4xE
    22 KiB
Reply 469 of 484, by digger
If it ain't broke, don't fix it. Fair enough. And I'm sure there's still good demand for a no-frills high-quality Covox Speech Thing clone.
But still, could at least some of these proposed improvements make it into a hypothetical CVX5?
Reply 470 of 484, by FreddyV
dreamblaster wrote on 2022-05-22, 15:43:
You sent me some devices to implement in Mod Master, but you have not done video with it so far 😀
Reply 471 of 484, by dreamblaster
FreddyV wrote on 2022-06-22, 07:42:
yeah i should do it this summer !
Reply 472 of 484, by dreamblaster
New video by Retro Erik, showing the use of 2xCVX4 for stereo sound.
It sounds superb ! : https://youtu.be/l-YWzQNLti8?si=yvaNKdyBW6y0zsHO
Reply 473 of 484, by digger
dreamblaster wrote on 2023-09-02, 07:24:
I know this has been asked before, but would you consider making a CVX5 with Stereo-on-1 compatibility, so that stereo sound could be played back on a single LPT port?
See my earlier post above for a schematic.
Reply 476 of 484, by ViTi95
Scali wrote on 2023-09-04, 10:23:
ViTi95 wrote on 2023-09-03, 22:32:
I'd pay for a stereo-on-1 CVX5.
Picture this: CVX5.1
That's a 5-bit LPT DAC that uses 3 bits to select which speaker the sample goes to. After released, someone modifies Doom to make it 5.1 compatible on a 486 😂.
Reply 477 of 484, by digger
Maybe you could increase the "demand" for such a CVX5 by adding Stereo-on-1 support to FastDOOM, @ViTi95? 😇
EDIT: Ah, chicken-and-egg, huh? You're probably waiting for it to become available so you'll be able to test such an implementation.
Reply 478 of 484, by digger
With S/PDIF output, of course! 😁
Reply 479 of 484, by darry
digger wrote on 2023-09-04, 16:15:
That is an interesting idea, except for these points, AFAIU :
a) Output would likely need to be upsampled to at least 32KHz (I do not have a anything with an S/PDIF input that supports less than that, AFAIK)
b) Low pass filtering would need to be done in the digital domain
The above would increase the cost, but might well be worth it. That being said, if the horsepower to do that were to be added, why not scope creep it a bit more and add an FM synth option too (real chip or emulated) ?
